CG Showcase of Overbalanced Wheel
Started by helloha, September 20, 2012, 09:55:52 PM
helloha
another way to utilizing hydro and gravity
helloha
Algodoo index XX. a simple try at setting up a vibration concept
TkMhMefan
helloha,
Thank you for your research.  I read your posts everyday.  I also see the logic in your experimental designs. Thank you for your hard work.  I am interested in what you have discovered that seems most promising.  I have seen a few that I believe are close or appears to be so.
--Fan of helloha
helloha
TkMhMefan,
thks for the compliment. anyway some of the research design/ideas is stuff that i came upon on the internet,
example like the vibration posted above from this site http://www.mitsubishielectric.com/company/environment/ecotopics/vibration/spring/index.html, i just use a bit of imagination to piece up the description, so these ideas are kind-of pretty close to what they appears to be so (but i don't claim credit for that  :'(   :P )
_______________________________________________
Algodoo index XXI. using fluid to hit on the vibration board
just an added info:
vibration generator can go hand-in-hand with the solar panel (can install the vibration board underneath the solar panel), so when in sunny weather, the solar generate energy, whereas in windy or rainy weather, the wind hit the solar panel causing vibration, which in turn also generate energy (raindrop hit the solar panel, also do the same)
helloha
Algodoo index XXII. recently just discovered algodoo can sim magnet behavior
