Magnets/Buoyancy
Started by KSW, April 13, 2005, 01:37:06 PM
DarkLight
That is no so important. May be it will be good to block the motor when we put it into the water.  In this position the elements are conected whit each other and with the air above the surface. When  all heavy plates reach their equilibrium position, we remove the conection with air above  (elements remain conected with each other) and unblock the motor.  To keep constant conection with the air above the surface is the best case, but there will be too much constructive dificulties I think.
This will work . The problem is that it will be too heavy with low power output. Because of it's weight and water friction it will turn very slowly. I don't think that is the future of free energy, but the principle is important  :)
Omnibus
Darklight, this is one of the most interesting ideas I?ve seen and I strongly encourage you to make a working model. Never mind the now seeming impracticality of the device. The importance of a working model goes well beyond its direct practical application. It will show that excess energy can be produced by a mechanical device in another conservative field but magnetic one. This will have far-reaching consequences.
macelyne
This concept is similar to an idea I had last year, ( See picture 1)
Finally I found out that the wheel can't work.
I'm afraid that your design has the same problems....
But when I interpret your picture well, it should look more like this ( picture 2 )
I have just drawn it, without thinking very much about it.
What do you think ?
macelyne
Omnibus
I just came upon this http://www.lhup.edu/~dsimanek/museum/themes/buoyant.htm. Obviously, these ideas have been around for some time. So far, the only viable ones for production of excess energy that have been demonstrated convincingly are the production of excess energy in an undivided electrolysis cell (continuous), the SMOT (periodic) and probably the Wesley Snyder motor (continuous). This doesn?t mean that other viable principles are impossible, including those based on buoyancy.
