Crystal Cell Research
Started by plengo, October 29, 2012, 06:08:15 PM
halfvulcan
Update on my own thing.
As mentioned, I didn't make these copper wire core cells correctly to begin with. I didn't give them enough time to dry before puttting the outer aluminum around them. But, I allowed more time to dry now, then dismantled the ones that seem dead or weak (lacking voltage or less than .1 milliamps). The ones that survived, 16 of them, are showing between .2 and .4 milliamps,  less milliamps than when they were new and metal-eating galvanic. After giving them plenty more time to dry and grow their crystals, I saw spots of dark crystal bubbles that forced themselves out through the aluminum foil. I put an additional foil layer around the existing foil of each cell . Then I put 3 series groups of 5 in parallel, and put those in a sealed glass jar powering my led bicycle lights. Not as much voltage or amps as last time with this setup. The lights are supposed to run on 3 volts, but my voltage from the cells is 2.88, which should be fine I think, but because of the lower amps than before, the lights are a bit dimmer. So, we'll see. I found a huge glass jar in the attic of my house that was perfect for this. I didn't trust the seal around the lid, so I melted some soft candle wax into it to make a good seal.
For more information about these kinds of cells, I'd say look up Ibpointless2's Youtube videos. He's documented some of his crystal cells so well that even a beginner can follow it.
My results are typically the outcome if you do things wrong. Crystal cells have proven to have potential for unending power. They're almost ready to deliver just that. The typical problem seen with them is keeping them from degrading due to chemical processes over time.
mscoffman
Quote from: halfvulcan on April 17, 2014, 06:17:27 PM
halfvulcan,
You should keep going. Cable and wire making manufacturing has been going on for a long time.
So you could get lots of ideas, at least, in how to perform certain functions. All you need is a core material
formulation. It's especially true if you have the battery retain wire's flexibility. You could wind it on a coil form.
I would certainly buy some if it was available. All someone has to do is build some and everyone will want it.
I also think you should take my advice and try higher electronegativity metal foils to see if you can get the voltage
up.
:S:MarkSCoffman
jbignes5
Quote from: halfvulcan on April 14, 2014, 03:03:30 PM
Why don't we all have solar cells powering our homes right now? You should scrutinize your own personal answer to that question. Okay, then ask yourself why your neighbor doesn't. Why everyone else doesn't? Solar cells have gotten pretty cheap now. People's eyes are closed.
We shouldn't be hoarding knowledge when it's knowledge of things that can save all of us. We should be sharing it as loudly as possible. Get it out there. That way, when the internet is ceized and censored, liberty doesn't die, it's reborn, empowered by independence that free energy gives.
Now they are bringing out new tariffs on solar setups. They want 5 bucks/month to pay to the power companies for maintenance and such. Even when you are selling the power back to them they are now putting charges on that. I mean now it is 5 a month how much will it be next year or the year after that? No matter what you do they have their hand out. I thought they charged the customer for line maintenance and not the supplier? Maybe it is both, Is this double dipping?
As for IBpointless2 Well I trust him explicitly. Especially when it comes to real Crystal batteries.
Allwest has a formula that he has chosen to keep a mystery. I think in one of his videos he tells why. He is applying for a patent I believe. Thats within his rights. Not everything is open sourced and if he is showing some great results like he is then I would start thinking the same way. I wish Allwest all the best and GREAT work my friend.
mscoffman
Quote from: jbignes5 on April 18, 2014, 09:48:39 AM
Once the electrical utility companies get the idea about what they are up against these payments for power sharing are
going to go the way of a July snowfall. I would encourage everyone who purchases a utility line interactive inverter front end
to make sure that their inverter can function in stand-alone as well as line-interactive mode as an option then to "make hay
while the sun shines".
Allwest
Thanks
