Crystal Cell Research
Started by plengo, October 29, 2012, 06:08:15 PM
Hi Fausto,
look at Robert Murray-Smith on Youtube.
He had a successful Indigogo campaign and is now selling his
ink.
Well he delivered for 10 GBPounds some ink in his campaign.
Well people want something in return for their donations I guess
nowadays.
Maybe you can make it much cheaper by not putting it into this resin
and just sell these cells with a hardwired LED in a cheap case ?
Bedinis Alaun Battery LED thing was just too expensive at 200 US$,
okay, it was also a bit more complicated to make, but here
we just want a crystall cell that lasts...
A friend of mine, just did a combination of a selfmade copperoxid - magnesium solarcell
which can put out around 200 to 900 MilliVolts, depending on the
solar light, but works more like a light chargeable capacitor with a crystal battery effect
included, so producing also power in darkness....only the current still has to be raised,
cause it is still only in the mikroamps range...
so there is progress on all sides...
Regards, Stefan.
Doug1
If your still looking for castolite Maybe you should talk to the people at Smoothon.com they have it under a different name "Crystal clear". They have a lot of stuff even a aluminum resin for making heat sinks.
  A trick I used to employ to cut down casting costs is to use fillers. Since I made my own molds using fillers became a big money saver in making the molds and product. Reducing the materials sometimes down 25 percent,I even recycled the waste as filler to avoid being hit with a local waste tax. It pissed off the county tax people which just made it all the more fun. Just follow the safety instructions of the products some repeated chemical exposures leave you hyper sensitive to exposures of other chemicals.
Doug1
Nearly free bottle caps? Go to where the beer is consumed in large amounts, Colleges ,dorms ,bars, and make an offer or attach in some way to sponsor donations to a cause like the wounded worrier fund or to some illness for bottle caps donated buy the pound. You and your wife will be up to eyeballs in bottle caps. Make up some Jars and slot the lid big enough for bottle caps to fit in and find some stores to let you place them on the counter. Cancer is always a good cause. You might even get a company like coke or pepsi to help promote it or Sam Adams or who ever.
Hay if people will dump ice water on themselves plus donate money I think you can pull off getting bottle caps for free.
plengo
Quote from: hartiberlin on August 29, 2014, 12:54:03 AM
Hi Fausto,
ink.
nowadays.
Regards, Stefan.
Hi Stefan,
I will again create a indigogo fund page but later when I have the product available so that people will have in what to believe in their hands.
Concerning a cheaper solution for the resin is that I NEED a total confinement of the cell without air or water entering the cell. THAT IS EXTREMELY IMPORTANT.
So my solution was the resin that makes the cell super durable (almost indestructible which people loves) and allow it to run for a lonnnnnnnng time, besides, if the cell is open to the environment I will have to hear the naysayers that the cell is absorbing moist from the air and therefore the cell is galvanic. The cell is only galvanic on the first week of formation after that she is a beauty.
Fausto.
jbignes5
Quote from: plengo on August 30, 2014, 10:19:05 PM
Hi Stefan,
Fausto.
Yeah I found that after the growth time for the crystals that there was little galvanic action as well but my cell never went past the begining stages. I went to the oscillator to experiment with to run from the cell and never really picked it back up. My version used not so active materials like aluminum and graphite. Not in the right proportions either. You have to balance the masses in my version to retain the materials.
The aluminum wire was heated and sprayed with borax, this formed a dry foam like coating. Then I baked it till it was golden brown. This creates a base crystal structure and when you put the aluminum wire into the crystal bath of alum borax and potassium it solidifies into a nice crystal structure that gets very clear and shinny on the aluminum. Once I let it set I start using the oscillator more and more to build a proper energy flow.
One mistake I made was to make the gap between the center graphite and the aluminum wire coil was too big and alot of crystal had to be formed and took way over a month to solidify fully. Using a smaller gap would decrease the solidity phase and increase the capacitance. My version came out to a volt but seem to get stronger current wise as the crystal formed, not in voltage but current capability.
The formula also included Epsom salts to give it pure water to form the other crystals with. No tap water was used on the recipe but I parboiled the glass jar I made the cell in and I assume the steam helped hydrate the mix a bit. I want to try the magnesium graphite or copper unit to see if it still works but magnesium is protected differently.
One interesting thing I found out about using graphite is that the crystals started growing into the graphite and that increases the surface area of the graphite. This could be the reason for the growth but I'll have to look into that more when I get back to experimenting with the cells again.
I hope everything goes well this time with the gogo plan Plengo. Having product to give out will only help the cause and might work really well to get the product out there and in the hands of the public. Word of mouth is the best seller of all.
