Introducing the flowerpot effect (rotary shaft magnet spinning out of control)
Started by AquariuZ, November 14, 2012, 10:45:29 AM
magnetman12003
Hi All,
I am magnetman12003 and POPSCAN1.
I invite you to look at all links below where I show how to construct it and I have included the parts list.
I open sourced the setup and its  published world wide now." PLEASE JOIN THE FORUM" the publisher setup for me. A lot of info is there also.  ITS ALL FREE. I dont want this technology to vanish as things that are to good often do.  The cats out of the bag!
Google  click:
Sat-gen Ferko Satellite Generator Magnetic power
os Tom Ferko's Satellite Generator- PESWiki
Honking on out--Fantastic speed
Scroll down the page untill you see the above
Tom Ferko
twinbeard
This is essentially a one magnet no bearing bedini motor, but with a shaft and bearing, using a diametrically magnetized tube magnet.  This works with the sphere magnets as well, and I have generally considered this to be a tuning factor of these types of devices.  This could effect the inductance of the coils, and the voltage induced along the trigger coil, which would in turn effect timing.  I like to envision it, however, as though it were allowing the overlapping of the interacting fields to behave like interlaced gears... get the positioning right, and its like the invisible gears line up correctly.  I show and describe the effect in this video:
http://www.youtube.com/watch?v=MGaYH9bKczk
Cheers
Twinbeard
magnetman12003
Quote from: AquariuZ on November 14, 2012, 01:13:14 PM
Tom has been here before - I just spent some time reading his posts and seeing other videos.
So nothing special about this 2inch spinning Neo held over a coil connected to a bendini circuit (appearantly)?
Something pulling 0.9 watts making a magnet accelerate like that? Wonder what you can generate if you put a load on the shaft.
I  already put a 1 pound load on the shaft and that spun with no problems.  A 16 inch diameter iron wheel was spun also. See the lighted  scooter wheels video.  I wish I had a way to measure shaft torque but I an sure someone that has access to a laboratory can replicate this and check torque.
clearchrome
Quote from: magnetman12003 on November 14, 2012, 01:20:07 PM
Hi All,
Google  click:
Tom Ferko
Hi, nice work ..
I was looking at the site: http://peswiki.com/index.php/OS:Tom_Ferko%27s_Satellite_Generator
I found out that the magnet cost around 175$ for 1 unit. I wanted to replicate it but, its kinda of out of my R&D budget.
Would it be possible to repro. your setup using low cost parts?
Also another thing to always keep in mind,  Your actually using 3.2W to power 4 leds and rotate a "not under load" Magnet!
It would be nice to correlate the speed vs input Watt usage and make a graph out of this.
AquariuZ
Hi All,
Google  click:
Tom Ferko
Hello Tom!
I will check out your info right now - thanks so much for posting.
AZ
