kapacitiv Transformer
Started by sergirafael, November 21, 2012, 05:37:47 PM
sergirafael
this picture explain what is say.
sergirafael
The speed in a three-phase generator has a frequency which represents a generator also has a natural frequency. To build a super-efficient generator for the Maxwell utilizes the electrical and inductive fields are set instead of the anchor, the Capacitive Transformer. The armature of an alternator is shorted, herewith are the electric fields in the anchor not being used and they are transformed into magnetic eddy currents. To prevent an eddy current will now take an anchor from transformer sheet capacity built as an electrolyte such as Air has. The capacity of the disk sizes and their distances l be switched in response to the coils parallel or in a series resonant circuit. At paralellschwingkreis itself is a very deep Z a very low internal resistance characteristic wherein it is desirable for a voltage source. In a series resonant circuit is very high, and thus the Z is a high given approximate to a power source. Performance adjustment of the load to the internal resistance allows for optimal balance. The speed of the external magnets generates an alternating field in Hz which the resonance frequency of the anchor which is to be replaced Kapazitiventransformer equal. The given circuit must be decoupled via diodes so that the load is not the resonance zusammenreisst complete. A positive feedback or negative feedback to the electric and magnetic field lines generated by the polarities and the running time difference. Of course, the connection of the coil to the capacitor or cut through a switching element and a diode, it is flowing to the imagination of the developer left. Cource with kind permission for reproduction and replication Open
sergirafael
The electrostatic charge is a charge Potentaildifferent between two surfaces. It can be considered wherein a gradient plate is enriched with electrons and the positively charged ions of opposite polarity. An accumulation of electrons on a plate or surface leads to the electrostatic effect. The electrostatic effect is observed everywhere where friction on surface materials ensteht. The friction energy to synthetic fabrics and Plasiken possible charge the material. Amber is rubbed on a Lamfell ensteht a strong electrostatic force. If a substance Sythetischer e.g. A trainer at a lambskin rubbed so already incur considerable spark discharges. By frictional electricity to produce economically has a material property to be found which has a high flat Oberflächenstrucktur. The material properties and the nature of the friction Nailon allows to generate a high electricity. This high voltage of 50 000 volts which is so loaded, however, has little amount of electrons to a high current flow to be generated. Current flow is defined by the amount of electrons. The electrons flow quantity is important so one can bennenenswerter power. The electrostatic fields to the body can be crucial to feel a wellbeing. If a coach jacket worn beneath a sheepskin jacket, this creates an increased electrostatic charge on the body. This can help if you feel disturbed by electromagnetic pollution. The organism and the organisms respond positively to electron accumulation by electrostatics. To walk barefoot is one way to earth. It is also possible in the shoe sole Piezzolautsprecher or below the drive chuck to generate do when running sufficient electrostatic force. The organism communicates via electrostatic lighting effects and the cell structures in the body are Infromiert about weak fields of 20 mV as a collective over the smallest electrostatic fields on their function.
Electrostatic fields Fairs
Electrostatic fields can be measured. A component is the variable capacitor what in old radios used is, the exposed plates can be schlosen to an instrumentation amplifier, and thus there is at the output of instrumentation amplifier an analogue voltage swing when the capacitors Plate is glegt into an electrostatic alternating field.
The songs bottle with gold foil in the middle is also a possibility to measure electrostatic fields. There do different measurement methods to measure electrostatic Fleder. It always requires a reaction that appears. An effect caused by a change in the direction of the force field lines. A very simple and old method of measurement is called a spring Flausel Indeanerfeder track down the fields. The Indeanerfeder anähernd a tree trunk hit by the electrostatic field in such a way at the top of Flauseln move downward. So the Flauseln do in Electrostatic Field move. The tree gives the tree its electricity Spirit's character and property. This is not respected today and this also needs to Respect when infested with the polluters which radio technicians build the environment. The tree electricity is generated when the water flows into the capillaries which act by friction and the energy Kapilareffekt. Since a tree is rooted deep, he has a very good grounding and a radio technician I know that tree death and dying forests is always associated in connection with broadcasting. Radio technologies disturb the natural electrostatic field of living things by the information in the body or in the upper layers of the hypodermis is gestörrt or Modified. The Flugrute a bee is the bee electrostatically erspürrt a bird also has a magnetic sense of direction. When the bee can not find the information for the flight back to the sensors they got lost and died unfortunately. Electrostatic fields are also given along the body, they are very weak, but also very important. Astrahl the body of people is partly electrostatic and he is a part of the consciousness of living beings. This is exposed wikürlich allenmöglichen radio signals and can sicken people in an unnatural way.
Mensché who wrote about Levitation in old books from the year 1970 (flea market and Brockaden was thanks!) Declared their ability to Levitate because of the spirit which envelops them. In the branch of metaphysics people are in your development may hopefully gain experience. Static electricity can be very full of energy and are always charged capacitors between sheets. The potential difference is always a lot of electrons.
Generate electrostatic levitation
If a vehicle has a higher amount of electrons is accumulated as the Earth has thus results one floating effect or levitation. Technorama in a public demonstration is very funny, if a child is at Langhariges plastic pedestal and touches one electrostatic charge sphere. The hair standing berege einwenig shows the levitation by the hair. Levitation is a special kind of Elektrostatika, levitation occurs weill the quantity of electrons is higher than the amount of electrons of the earth. Levitation is one of the things mitdem hopefully in the future, the space can be revolutionized. Levitation caused by the change of the electron accumulation Raumskalar through to a surface. Said Raumskalar is amended to remove an electron, of course. The time and the included Raumskalar sensation can be varied by a high Elektrostatika. The Raumskalargrösse thing is a consideration and objectivity is to illustrate the Raumskalar from the viewpoint of a Elektrones one other than objectivity which we humans have. The Raumskalra in contemplation, from an electron from being stretched endlessly. The reason it long lives for us viewers.
Curvature of space and spatial expansion of electrons
An electron has a function room extension. Strain produces antigravity space and an inverse change of the time, the information being coupled to the Maxwell Quantenüphysikalisch by magnetism. The string or Satieneffekt is by stretching the Raumskalar one spit effect chamber elongation and the change of the information on an electron, the second coupled to local electron reach immediately. The dimensioning of the information is a step higher than the dimensions of time. I explain the gap effect and thus that Interefferenz particles wave phenomenon is a change in connection Raumskalargrösse stehtend. By interagierung with the matter wave is gebremmst strong. The space around the particle (electron or photon) is suddenly changed. The oscillation is a Raumskalargrösse with gehdehntem space, the rest is a particle Raumskalargrösse, scrunched space. That the space is changed by braking or beschläunigung the electron. Einstiens formulation describes it, because I want to hold on to. The Raumskalaränderung creates a strong energy, the zero point energy research in which. {Space and time (a Commercial magazine) Issue 10 2011} there is angeknüft and the information could be found for me in the Journal A Raumskalaränderung is a change in the space by the decelerating expansion of the electron. The braking of the EM wave in femtosecond generates a complex, wherein the space of strain suddenly comes into an upsetting. The space compression produced depending on the energy and mass of the electron radiation. The abrupt change of the space around the electron can also cause an effect that two of the same particles exist in the same place for us viewers, anyway. There is the space curvature, a lens effect ÖFT if one sees the satellite photos are taken about half of magnetic Amomalien. An electron can Raudehnundgsfunktion basis of which it itself auslösst gringe by its mass and the high kinetic Energiepotental produce on the matter levitation. Levitation caused the more electron is present on a Masser as matter. The Skinneffekt is overcome. The Skinneffekt of high voltage can be exploited to the property, and the weight of material to change. Electrons which are thus rectified and can not Wedendorf discharged by a current or a potential Different thus also cool a body. The material as the temperature is reduced by vibration. The heating of matter by electromagnetic turbulence in microwaves is known, burns around the ear by heating can be observed. Interestingly, the cooling is by electron accumulation as it is to be found in the Peltier element. The Peltier element is an array of transitions PN, by the current flow, the one side and cools the heat removed by these electrons jeodch enrichment of the N substrates.
sergirafael
The weak gravitational force increases it by the accumulation of masses, however, are large masses encounter like planets also from each other. The Raumkruemung which is caused by the gravitational mass on approach of two major mass pile a negative attraction erzuegt because the space constant is gekruemt. The space can be stretched and compressed. Saklar space is stretched when there is a very small mass, for example, an electron. A room can be upset when a large mass is present, for example, a black hole. Electrostatic force is defined as a strong force. Electrostatic levitation force produced one Schwebeffekt. Electron accumulation of metal alloy levitates the metal. An electron has a single particle with its mass and its Beschlaeunigung a functional space in which to bend Permits near the room at the electron well. This collection of electrons generated by Raumkruemmung levitation. We only look from one to the other Raumskalargroesse electron, therefore, I see now the electron as a wave motion, however, the particles which bends space as such. The curvature of space success by strong magnetic force, thus there is a bulge on my studies, we have a book of my ancient physics Raumwoelbung generated thereby. This is a lens effect, therefore, the danger is there, now that an electron in two places at the same time as the particle exists. The information which the electron is in itself bears therefore no longer koheraent with the reality that Schwinung was destroyed by the magnetic space injury but is it possible the same electron at the same time can be observed more times. The spatial distortion caused by masses is a complex, which represents the time, as such, in the information. Quantum entanglement is a phenomenon of the information where the space is stretched around the electron, thus the time for the transmission of information in quantum entanglement vekürzt. So high distance, a Quantum Entangled electron pair dual react simultaneously. The information is considered to be a constant when the space moves scalar. A spatial displacement is generated at about the electron velocity and the frequency. I think that an electron with its small mass with the increase of the speed of the space IMENS expands into itself, it wessewegen much longer lives and it also acts as an extreme energy Frequentiale vibration. The properties of space-time compression and expansion now makes the electron is extremely long life, at least for us observers. The bulk density and time course is inversely proportional. If the electron now interacts with an elementary or atomic union Valenzelektronverschiebung Sun radiate from a force. A radiation into light, Roentgen or Gammastralung arises when this Valenzbandwechsel is strong. Here, the space or the Raumsakalargrösse is changed abruptly. By beschleundigung braking and high speeds of the space around the electron with the fact-comprising energy is changed rapidly. A change means that the energy acts. The given quantities of radiation is defined by the speed or even in the course of scalars braking space. The space of one to the other is a few Valenzelektronenzustand angstrom, so now the electron acceleration or velocity times frequency prevail how many photons are emitted by the elementary. The uniting of elktrostatischen force and the radiation is thus dependent through the material spacing in Angstrom and the valence electrons. Radioactivity is reduced by Fuleren 90, dolomite and quartz crystal. The solid state physical properties of the crystals by allowing enrichment of electron beams leave. This may be light, X-rays or gamma rays. Depending on the amount of electron (electron current) Freuqenz and acceleration or Abbremsungsgeschwindigkeit. The radioactive radiation or light, and can also be converted into a reabsobiert potential difference gap voltage. The solid state physics with the lattice spacing of crystals and their Eigenschwinungung (temperature dependent) allow the interaction of electrostatic coloumbkraft and understanding of radioactivity. High electrostatic force enables to change the time constant, a high electrostatic force enables to REDUCE the Zervallszeit or extend the higher the frequency of the Electrostatic potentials is the faster the time measured. The molar rate of matter is represented by the light beams in Planck color than temperature. The frequency in Hertz is liniear convert it. The Skinneffekt of matter in white heat means that even Hot Iron in white heat has a similar Skinneffekt as high voltage, it might even be touched by hand. Skinneffekt of the high voltage has a very cooling and temperature-lowering property. The electron accumulation in the molecular structure can be the frequency, and thus reduce the temperature oscillation. Thus can cool off Electrostatically. The duality of the temperature with the frequency is important schwinung the Molecular to measure the heart, thereby Electromagnetically the material may be so excited that it will be easier and more energy efficient reabsobiert from an acid leach Elementary. Skinneffekt of the high voltage can be applied to water, thus can be a hard hydrogen build in the surface tension of water is so high that it is mechanically stable.
phoneboy
Nice to see someone finally getting the concept, good luck with your devices.
