9/11 truth movement topic
Started by FreeEnergy, August 01, 2006, 06:08:06 AM
Should we leave this thread on overunity.com ?
Yes, leave it here, we have to expose the inside job.
No, delete this thread, political things don't fit over here.
I don't have time for this!
I don't care!
Remove this poll!
d3adp00l
Hey ring as far as proof for building 7, read the thread. as far as honor goes, so what we should just shutup and let the honor of our country go to crap. As far as anarchy, so what we should do is allow what every knows to be corrupt to still exist and not change it. Ok Benedict, do you work for the government, with the way you double talk, and bring up the same old points that have been destroyed time and time again, I would say that YOU stand to lose something and you are fighting an irrational fight to keep it.
Face it here are the facts, and they have been presented multiple times on this thread, look it up.
Buildings 1&2, could not fail due to fuel fire, could not cause earthquake explosions, was not hot enough to stop people from being very close to the fires, was designed to withstand such an incident, would not have sustained damage from explosions prior to plane impact, would not have had damage in lobby, would not have had multiple explosions throughout the building, would not have collapsed in 9 seconds, would not have collapsed into itself which would take the most energy, would not have main support collumns cut, would not have enough energy to melt steel, would not have enough energy to remain hot for a month, would not have enough energy to powderize concrete or the rest of the contents of the building, would not expel jets off the side in a collapse, how does a plane hit this buildng and is somehow hot enough to melt steel but the same type of plane hits the pentagon and can't even burn a couple floors leaving wood desks stools books computers and everything else, want more?!?!
Building 7 would not have collapsed from a few fires, had little damage from failing debris meaning structure intact, would not fall in a few seconds, would not fall from the top down, would not fall into its own footprint, would not have two fracture lines vertically on the sides of the building, would have some explanation in the nist report, would not be hot enough to smolder for months, would not be hot enough to melt steel, would not collapse its basement, if building 4 had 1/4 of the building still standing after the debris leveled the rest and that 1/4 had to be dropped with demo cranes later then there is not reason for 7 to have every dropped,why announce (bbc,cnn)  that 7 had dropped when it hadn't if no one already knew, what happened to all the investigations that the building held paperwork for- are they still ongoing,Want more?!?!
World trade center, why would a buildings power be shut down for communication wiring, just to let you all know the systems are 100% independant of eachother and there is no reason on earth for doing that, if there was warning (which officials have said many times) why relax security, if the buildings were losing money for the port auth. which made them chose to lease it for 99 years why reward the "investor" with a grand total of 8.4 bil $, who made the money on the recycleing instead of investigating it, where is the gold, why does it seem that there was a ton of insider bank account transactions, would bought the "put" options, why when security is relaxed and cameras/card locks down would you "rewire" a building, you did that work and where is the permit for it, who is now paying for the new construction, and who all benefits from it. Turning a couple hundred grand into a new super tower with no mortgage is a neat trick.
Pentagon, wheres the plane, wheres the plane, wheres the plane, how did the hole get into the buildings,why is the damaged light poles and yet no debris, why are there windows intact in the place where the plane would have hit, how did a plane "vaporize" for the first time ever and yet make holes in an armored building, did I say wheres the plane, where video of the impact every inche of the building is under camera, why did the section collapse, not enough heat to burn books and stools, what was in the wood box, where are the bodies of the occupants, why is the plane still listed active, wheres the luggage , wheres the seats, wheres the plane, how does an elephant of an airplane invade the world's most secure airspace, and how does that elephant do a u turn in that airspace, hours after we "know" we are under an attack, why is there enough energy to vaporize an entire plane and its contents but the few so called parts of the skin are completely fresh and clean, how does a couple engine parts end up at a crash scene that could not of came from the type of plane that was said to hit it, how does a wheel shrink, no plane has ever crashed no matter the speed without leaving nearly all the plane left, how does a plane hit this building and barely burns leaving wood, paper, plastic, and everything but hit the wtc and somehow melts steel, and how does the plane even pull the last manuever when the fly by wire software system WILL NOT ALLOW such turns to be made, why does the FDR black box data not match the needed altitudes or angles to hit the building if it is the data from that plane, how does that box survive and yet so many others don't, remember the plane was vaporized, wheres the other engine, and how did the one engine shrink, why was evidence removed before it was tagged in its locations (a federal crime), Want more?!?!
Flight 93 how does it land in chicago and yet cash in penn., how does it leave no bodies luggage seats etc, how does most of it evaporate, how does it for the first time in history leave a crater, how is it not intercepted many hours after attacks, how are cell phones working, how is it that the scene is locked down almost imediately, how is it forgotten, how is it that most of the plane was vaporized but not enough heat to damage a nearby house, want more?!?!
Passports,passenger logs,remains,lists of the dead from the planes, and on and on and on
How is it that people did this
and how is it that so many accept the lies
how is it that you fabricate explanations to support it
is this a magic plane theory, like the magic bullet that hit jfk,
You sir are either so dependant on this system that you would rather live in this muck, or a supporter of the system that would allow, help, condone what happened.
History is full of people who out of fear,
Or ignorance, or lust for power have
destroyed knowledge of immeasurable
value which truly belongs to us all.
WE must not let it happen again.
-Carl Sagan
ring_theory
@ Stefan
Oh now your believing in mainstream science to explain something? Maybe overunity and free-energy don't exist as they suggest?
Answer me this! Is it possible that a thermite reaction could have freakishly occured if the correct elements and conditions were present? I'm not going into it but the plane was aluminium.
@ Dingus
You replaced tv with youtube.  :( You didn't escape the conditioning you gave it free reign to condition you any way you want to be conditioned. "Keep an open mind but not so open your mind falls out" - ring. There was enough accumulated energy with Jet fuel, contents, airliner, oxygen rushing through the towers to suffeciently melt iron. Ok so if thermite was present and it is possible that it could have been. How did it come about? delivered hastily by firemen? meticulasly installed in black ops? Or a result of flying an aircraft into it? wasn't those planes i seen flying into them? all evidence points to the latter of the three. and nothing to support the previous two.  ::)
HopeForHumanity
May I remind people again, fuel will only explode when under pressure or as a fume. The plane was fueled not to long ago(low fume level), and the plane crashing into the building depressurized the fuel. The accumulative temperature of the ignited fuel could not have melted the steel, infact, coolent on the airplane would have lowered it even more. I remmeber reading somewhere very long ago that all the important executives were told not to come to work that day. Many firemen were already ready before the plane crashed(wtf). The wtc fell as if the floors stacked like pancakes, the same as a controlled demolition.
Don't worry, why would the government have a reason to decieve us? ;) :D
Ron Paul is internet overunity: http://www.youtube.com/watch?v=vXnBZd4nyWk
WE MUST STOP THIS! Free energy is being surpressed because of it!
FreeEnergy
oops i posted in the wrong thread, sorry.
ring_theory
Quote from: HopeForHumanity on August 04, 2007, 04:33:03 PM
Why does everyone ignore the fact that there was other factors involved? like that the fuel ignited the contents of the building of the effected crash area. what about the fact that the wind was blowing right through the building increasing the temp of the fire.  ::)
