Lynx Joule Inverter
Started by Lynxsteam, November 29, 2012, 12:42:40 PM
synchro1
Quote from: totoalas on December 27, 2012, 04:14:27 AM
Ps check ac neutral rf charger load 2471212  yt imtotob    cannot access my desktop pc
Load comparison
http://www.youtube.com/watch?v=3E5mAkqwnRw
"The Ambient Power Module (APM) is a simple electronic circuit which, when connected to antenna and earth ground, will deliver low voltage up to several milliwatts".
"Generally a long wire antenna about 100' long and elevated in a horizontal position about 30' above ground works best. A longer antenna may be required in some locations".
The power from the APM with a single wire antenna is .002 watts compared to the 3 plus watts off the A.C. neutral line. That's thousands of times more power with the same APM! This simple discovery by Totoalas is quantum leap!
Even more amazing is the increased bulb brightness Totoalas gets just between the A.C. neutral line and the earth ground alone, without the APM! Apparently, the 220 volt LED bulb circuit is doing a better job at collecting and rectifying the energy then Joe Tate's Ambient Power Module. How utterly stupendous and flabbergasting a breakthrough discovery!
I believe now that the power is "BROADCAST FREQUENCY GROUND RESONANCE" between the grounds. There's even a stronger likelyhood that both the ground resonance and RF reciever operating theories are correct. Nicola Tesla recieved the first broadcast signal from Outerspace, patented the first ground antenna ambient power generator, set the powerline Hertz, and our electric wire gauge. There're possibly 3 or 4 sources reinforcing resonance. All these factors, born from the genius of one mind, may be at work powering these bulbs. One from the ground, another from Outerspace and third and fourth from the common denominator power line dimension and frequency.
With these theories in view, the question now is; How many 220 volt LED bulbs can we light in parallel between the A.C. neutral line and the earth ground? Some bulbs work better in parallel then others, and some other brands won't work wired together in series or parallel. There's one "Lights of America" bulb that seems to work very well both ways. Regardless, I think Totoalas may have just turned us all into Sheiks! Many thanks again to Totoalas for his awesome discovery.
totoalas
Thanks  synchro and the link to dr. Nakamats
Cheers
Totoalas
synchro1
@e2matrix,
An electrical connection to earth can be used as a reference potential for radio frequency signals for certain kinds of antennas. The part directly in contact with the earth - the "earth electrode" - can be as simple as a metal rod or stake driven into the earth, or a connection to buried metal water piping (though this carries the risk of the water pipe being later replaced with plastic). Because high frequency signals can flow to earth through capacitance, capacitance to ground is an important factor in effectiveness of signal grounds. Because of this a complex system of buried rods and wires can be effective. An ideal signal ground maintains zero voltage regardless of how much electric current flows into ground or out of ground. The resistance at the signal frequency of the electrode-to-earth connection determines its quality, and that quality is improved by increasing the surface area of the electrode in contact with the earth, increasing the depth to which it is driven, using several connected ground rods, increasing the moisture of the soil, improving the conductive mineral content of the soil, and increasing the land area covered by the ground system
Lakes
Totoalas, what do you measure between Neutral and Earth (with your DMM) no lamp or circuit connected?
Is your earth from the mains socket or an outside connection?
Does this only work with the circuit or "special" lamps?
I just measured between my earth and neutral connections on a UK socket and got nadda as expected.
(I would have been very worried to have read any voltage.)
totoalas
Hi
I used nomal dmm on the dc output of thecircuit
With ac neutral and earth  pipe in the faucet as ground measured zero on the ac voltage scale
If the neutral and earth get in contact the rcd breaker trips
An 8w fl tube will flash and a 3 w led lamp as well
