Lynx Joule Inverter
Started by Lynxsteam, November 29, 2012, 12:42:40 PM
gadgetmall
Lynx I want one but not at your expense . Thank you anyways for the kind offer but i am spent out this year(s) But it is one cool way to have light from a panel i'll bet . I also have 8 panels , 4 1 x 4 mounted on a sat dish mount to track the sun ( old curizo plant panels) they still put out 9 amps at 26 volts and i also got 4 newer Giant 4 x 2 panels . they put out 63 volts @ 50 watts  each  and charge some Airplane batterys . also have a windblue charging an 1100 pound forklift battery with gridtie and trace inverter. I love Them and the extra power they produce makes the light bill a 1/4of anyones bill out here .I am glad we all stride to make light from nothing ;)
just because i can't get them please keep experimenting with different transformers with other secondaries . I am very curious as to how much you can get off those .
MERRY CHRISTMAS
totoalas
Ive replicated Lynx RF diode charger by using ac neutral  as antenna  and it works
AC Neutral RF Charger 231212   Youtube  Imtotob
thanks to Lynx
totoalas :)
synchro1
Here's the link from Totoala's new video from above:
http://www.youtube.com/watch?v=zWbSTim5n0I
As I've pointed out in the past, output is directly proportional to antenna size. This innovation is a million times more powwrfull then a single strand of magnet wire streched 100 yards through the trees as an antenna.
Lynxsteam
Great.  Are you using AC neutral as in the neutral wire of your house grid?  Isn't Neutral usually also grounded?  So is the idea to use the power company's Nuetral as your antenna or ground?  Are you collecting RF energy or AC inductance?  Is there any chance that live 120 vac is going to hit this circuit?
synchro1
Here's the link to Joe Tate's Ambient Power Module:
http://www.rexresearch.com/tate/tate.htm
What we're looking at here ladies and gentelmen is the key to limitless and abundant free energy for all. It's time to pop the corks. Hallelujah! Totoalas is using his body as a ground, but every outlet should have an Earth Ground and an A.C. neutral line that turns miles of overhead light lines into an an enormous radio frequency recieving antenna. There's no limit to the amount of power we can draw with Joe Tate's power module between those two wires. All that's needed is a battery to act as a voltage regulator. The APM won't charge lead acid batteries because the leakage is to high; However, 14 rechargeable nine volt Ni-Cad batteries in series will light 120 volt LEDS just wired directly to the two wires from the LED'S to base circuit. One can draw limitless power this way simply by adding power modules between the Earth Ground and the A.C. neutral line. The potential is limitless and non-exhaustive. The danger's exploding the batteries with insuffcient output, something I discovered the hard way.
A gift for the dawn of the Age of Aquarius from Totoalas! Blessings to everyone. I'm overjoyed. Thanks Totoalas, you're the best pal!
