electron zentripedale
Started by sergirafael, December 12, 2012, 01:41:53 PM
sergirafael
A littel condidutaction of piezo crystal generator whit wire core and capacitors
http://youtu.be/6UV8iAzozCc
a littel explain of wired crystal coils and capacitors
http://youtu.be/7mgEyvXE_cw
sergirafael
Long quartz crystal included are some at slow frequencies around 20 kilohertz and below, to arrive by vibration or by induction in natural resonance. Calculation basis umd Long artificially bred quartz crystals to bring in electric self-resonance are described within the Klass sian Festkörperühysik.
Additional Notes https://de.wikipedia.org/wiki/Schwingquarz
https://www.youtube.com/watch?v=CBOxU_mYXto
If one wants to the energy density of a coil with the energy density of a capacitor and the energy density of quartz crystal combined, so I bring a sample structure for it.
1. A quartz crystal of length 35 cm is wrapped with a resonant transformer.
It should be noted that the isolation of the copper wire is high voltage fixed.
https://www.youtube.com/watch?v=Y_YwPyQGxWw
2. To a hard cardboard or PVC pipe, a capacitor in old educational nature is rolled.
In order to turn the element in the high-voltage self-resonance used as switching frequency.
https://www.youtube.com/watch?v=ZfwxkuqupR4
As a switching element, a circuit breaker Alternator of a brush motor is ideal to switch short Spannungsimpule on the component.
The power density is increased, thereby veringert on space requirements.
Quartz crystals that have been artificially bred suitable for high voltage generation when the purity is exceeded K4 is therefore of natural quartz crystals with inclusions not to be recommended.
Turmalinquarzkristalle, or radioactive irradiated Rauchkquarzkristalle with Ferriteinschlüsse turn intrinsically even better for piezocrystal effects evoke.
A quartz crystal can be put edit by an AC voltage within the predetermined resonant frequency in mechanical vibration.
By virbration hammering or within the resonant frequency of the quartz crystal, the crystal image generates high voltage, below, piezo ignition as the simplest example.
Is an electrostatic or electromagnetic field or both Fleder applied as in the pattern structure as the resonance frequency is also as a vibration modulated onto the quartz crystal, which in turn with an extremely high power density, the effected change in density for Plamaerzeugung for Skinneffekte at supersaturation of this oscillation.
To generate high voltage of several billions or millions of volts during a short period of a few picoseconds, this is the ideal generator.
This founding of two,
1. The electrostatic as well as the electromagnetic component is taken into account which involves Maxwell's formulation
2. The power density increases by a factor of 5, in addition to the overall size becomes smaller for the usable energy.
A quartz crystal can be used just like a wheel Dia also in rotation, but must temperature at 450 to 550 degrees Celsius are operated in Curie ideally. The velocity of circulation are the mechanical and simultaneously Elektromagneitsche resonant frequency again.
Therefore you will receive a Schwingrkeis with extremely good quality, a super-precision PID controller.
The idea I had come to a dream, but I did not dream of the these structures since 1987 in operation.
Each Teilchenbeschläuniger in Amerkia France and China produce high voltage with quartz crystals.
For high voltage worth reading: http://www.free-energy-info.com/German/Chapter5G.html
I translate to high voltage, the findings of the
 1889, while the knowledge below has been maintained at a high voltage experiment.
By very short pulses in a resonant transformer, this produced very sharp shockwaves.
This shock wave was felt across the front of the body of Mr. Tesla.
Now Biffilar (green / brown) In a second pass is wound a second coil layer (ORANGE / BLUE) to the first coil layer. Image 1
Now the piezoelectric generator can be wrapped in a capacitor. Image. 2
In order to determine the resonant frequency to use just half an audio amplifier and connects one layer of the coil layer with it. On the second coil layer is measured in resonance frequency a voltage overshoot.
In order to obtain a very precise biffilare coil turn (the two wires same and equal values ​​includes induction)
which are puncture-proof at high voltage, used ideally 2 wire telephone wire or speaker wire.
Thus, a two-layer winding are obtained on the same level with the same values.
The mechanical vibration of the resonant frequency within the crystal, just half can be determined with a laser of Axial shines through the crystal.
The vibration is electrically / mechanically, can be inductively generated.
In the crystal length of 35 cm is the frequency in the audible range and very low, making the crystal of a piezoelectric crystal generator interesting on a flywheel.
He was aware that this was done on the high-voltage dynamo due to closure of a switch,
 a stinging blow eruhr his body.
 The high voltage of electrostatic electricity appeared during the activation for few milliseconds.
But where standing bluish needles of energy from the electric cables leaked in those few milliseconds on the ground, the bodies of all people were standing near, at risk.
 While the generators of that time reached to a few thousand volts, the discharges were several million volts in intensity. The generator problem was eliminated by the highly insulated switches which were used provided with a very large ground connection.
1890 Tesla researched further by experiments to examine what arrangements these high voltages generated.
 He was soon able to produce these shockwaves whenever he wanted.
 The shockwaves produced a stinging sensation no matter where he stood in his laboratory, and hands and face were particularly sensitive to the shaft.
These waves radiated and penetrated metal, glass and any other type of material. This was clearly not an electromagnetic wave, so he called the new wave 'Radiant Electricity'.
Operation of a motor with conventional electricity was hot under load.
 Turn off the same engine Radiant Energy electricity and loads the motor, so it was cold.
The effect of overloaded by stalling showed how the motor housing are covered with frost. Therefore, this form of electricity is referred to as "cold" stream.
It is not advisable inbetriebzunehmen these structures outside the laboratory condition, since plasma clouds cause a phenomenon with which one is overwhelmed when tinkering.
sergirafael
To a quartz crystal Eigenresonanazfrequenz to approach can be beaten with a hammer on the sound quartz rod.
The quartz rod should ideally be hung, so they can swing freely.
The frequency of a 25 cm long quartz crystal is so ca at 5.2 kilohertz.
If the quartz rod is suspended and is then struck with a hammer so the resonant frequency or natural frequency of the quartz rod sounds about 20 to 30 seconds after the hammer blow.
Now take a microphones this natural frequency vibration on, and can connect them to play through an audio amplifier.
The output of the audio amplifier is simply half switched to the long coil which ensnared the quartz crystal.
Now it is still important to the induction of long coil which was wound around the piezoelectric crystal to wind a capacity with aluminum foil.
The through bone and marrow and through walls (reinforced concrete) urgent sound which now occupies the space shows whether the quartz crystal is in Eigenresnonanzfrequez.
If one wants to turn this natural frequency with high voltage on the long coil, used ideally an alternator of a Gleichstromotores, so the breaker.
The spark gap should come to lie over halfway 50 000 volts. Now you have to watch, radiation protection standards as the hard X ray radiation should be noted Rötngenstrahlung is generated from an electron acceleration 25 000 volts.
This mechanical self-resonant frequency of the electromagnetic entspircht equal natural resonant frequency.
Must be rotated to bring the Quarzkrsitallstab by rotation in this frequency of the quartz rod with 5200 revolutions per second around its own axis.By degeneration by mechanical vibration which Symentrie the matter is repealed. The dense distortion as a change as an electromagnetic oscillation generates a splitting of the valence electrons, the energy of the valence electron transitions corresponding to the electrical Dichteaenderung within the matter, just rearranging the Aufenthaltswarscheinlichkeit of valence electrons.
Elements with tetraderische structures are very to save energy as Ferritre, or dispense with such crystals. An indication of the molecular physics reproduces the Jahn Teller effect. What the plasma generation with electromagnetically excited crystals regards as one comes between laser physics and even the piezoelectric effect to lie, said molecular rectifying play a very central role to win from a crystal energy.
We d a crystal mechanically in a vibration associated with a very high amplitude, or brought by a laser in Molecular resonance, or brought by eletkrischstatische and electric magnetic fields in resonance, the energy gain of plasma generation <by Dichteanederung within the Atomverbanede is considerably higher than the energy which is applied for the mechanical movement.
