25mV Joule Thief powered by peltier merely using our body heat -Free energy 24/7
Started by magpwr, December 20, 2012, 09:26:33 AM
scratchrobot
Quote from: magpwr on December 21, 2012, 07:15:42 AM
To Scratchrobot,
The reason why i am using 4JFET in parallel is to increase current output.Using 1 fet current consumption is only around 1mA and obvioiusly the output current is lower.THE jfet was not design to handle high current.
So I could also use just  one jfet with higher current rating and the result would be the same?
magpwr
To Scratchrobot,
You can use 1 JFet and get lower current ouput.These FET are not design for high current.
You will need to experiment to understand the logic on why i was using 4 JFET.
magpwr
To cuttinedge2005,
I think you have not calculated all the random possibility before replying to me.
Let me tell you where this circuit could be applied not in urban location where you assume there  is power even during disaster.
1)Industry application-monitor furance or engine temperature remotely without battery then transmit the information to a central location or control room remotely on interval basis.
2)For military or for hikers out in forested area where is no direct sunlight if you are on the move.
Gps or or other equipment could be trickle charged.
3)If peltier is installed into miners hat.It could serve as permanent emergency light even if the battery pack fails.
scratchrobot
Quote from: magpwr on December 21, 2012, 10:41:05 PM
To Scratchrobot,
Thanks i will as soon i have the jfets. Can you tell me the values of the caps you used because i cant read them in your video.
Quote from: onthecuttingedge2005 on December 22, 2012, 12:49:59 AM
serves no purpose in the real world.
At least this circuit is working and gives energy unlike most circuits here.
Not everything has to have a purpose.
