You can banned me and please remove my Energy amplification thread sir
Started by Tito L. Oracion, December 22, 2012, 11:53:04 PM
ramset
Bob
I have great respect for you and your sensible contributions,Part of the "Cure" is personal inventory and accountability. And what we do with what we know ultimately forms our destiny !
What I say to Teets is true ,becoming "aware" can truly drive a man to the edge.
My life is all about service these days as long as it may last.To have this tool that Tito Hides would surely stop much Death and suffering,for this he is accountable,many here are of the same mind set [they would help the needy] .
No it is true that you and I do not need this "power"for our next meal or Clean  Drink of water.
But the ones that Do are passing from this world as I type........
His guilty Crumbs of help offered ,make no sense coming from a man that Professes Christ.
Nonsense!!
That being said I will not play/post here anymore [Teetsla's pitty Thread],I'm taking My marbles and going home....[where the time spent is much more productive ]
Thx
Chet
Thanks Grandma
wattsup
Maybe @Tito is afraid that if he discloses his device and does a video, that eventually I will find his Wire X, and that would surely be worst then being hit by Gods Thunder.  :o hehehehehehehehehehe
@Tito, I did not go back to post often on your thread because for me, you fall into the Living Secret Holder category. When I talk to someone that is holding a secret and I ask him or her some questions, I expect that the person will have to lie or be evasive in order to converse without giving out the secret. So, there is really no point.
But one good thing about @Tito is at least he is not making endless videos showing OU where 100 researchers will be wasting their lives trying to find out how it is done. Better to hold a secret and show and say nothing then to steer OUers in 100 directions.
So, one day, when the clouds turn black and the air is thicker then saw dust and the water is smellier then a five day sock and the crops are poor and the world seems to be on the brink of total destruction, maybe you will decide to put a stop to all this madness and tell us your secret. Because crazy as it may seem, all it take is one small secret, from one small man, to fix the world.
Anyways @stefan has agreed to open a new forum category (I still have to decide what to name it) for me under which I will be moderator. I want to start showing what coils really are because we really don't know coils as well as we think and I am sure that once guys really now what a coil is and realize the fight that is required to make them work properly, this will lead eventually to many OU devices. We have been working in checkmate mode and need to look at coils and energy in a totally different way. Also, pulsing, like @Tito is saying can be done with a diode using the revere threshold or using a zener diode in new ways. Also, @allcanadian at OUR gave a really good paragraph on capacitors. I think once we solidify some base methods for OU research and get those out of the way to become standard practice, then once OU is shown, researchers will understand it so quickly and be able to use that new base principle in 1000's of different ways.
So we keep going.
wattsup
PS: Some guys are referring to a "W". Hope it's not me.  :P
Qwert
Quote from: wattsup on December 27, 2012, 01:00:34 PM
To be honest: what about Kapanadze? He doesn't fall under the LSH (Living Secret Holder category) measure?
wattsup
@ramset
Thanks for clarifying that.  So Will was a bad boy. I wonder what Santa brought him. hehehe
@Qwert
Yes TK is a LSH as well but he should be better known as the Notorious OU Copperfield or NOUC for short. He really NOUCed us good.
Off topic.
I have been thinking lately about the Rodin coil and how its center area is a tremendous source of spin energy. And then it dawned on me that maybe if one took a standard alternator stator and just wound a rodin coil over it, if the rodin center area can still create that spin, the stator should pick it up without any Lenz law. I will have to try that soon enough cause it could be a good, simple answer.
wattsup
Bob Smith
Quote from: Tito L. Oracion on December 26, 2012, 09:08:14 PM
In my definition of a diode, the one who knows the secret will know that i have it.  ;)
And this is the closest clue that i could ever give.  :)
Here it is: I'm using the diode as a pulse circuit controller.  8)
note: For every single pulse there should be an accumulation happening.  ;)
God bless and happy new year
Tito L. Oracion  ;D
I don't know if this is on track, but for what it's worth:
The zener diode is the simplest types of voltage regulator and the point at which a zener diode breaks down or conducts is called the "Zener Voltage" ( Vz ).
The Zener diode is like a general-purpose signal diode consisting of a silicon PN junction. When biased in the forward direction it behaves just like a normal signal diode passing the rated current, but as soon as a reverse voltage applied across the zener diode exceeds the rated voltage of the device, the diodes breakdown voltage VB is reached at which point a process called Avalanche Breakdown occurs in the semiconductor depletion layer and a current starts to flow through the diode to limit this increase in voltage.
The current now flowing through the zener diode increases dramatically to the maximum circuit value (which is usually limited by a series resistor) and once achived this reverse saturation current remains fairly constant over a wide range of applied voltages. This breakdown voltage point, VB is called the "zener voltage" for zener diodes and can range from less than one volt to hundreds of volts.
Source:  http://www.electronics-tutorials.ws/diode/diode_7.html
Again, maybe I'm off, but I thought I'd throw this in to hash around.
Bob
