1850 Watts free energy power ? New GEGENE circuit by JL Naudin shows COP = 2.8
Started by hartiberlin, December 29, 2012, 08:16:11 PM
Paul-R
Messing about with lamps or LEDs seems a waste of time.
JLN has been connecting up to a kettle and measuring the
rise in temp over a known time.
This must be the way to go.
Madebymonkeys
Quote from: ramset on January 11, 2013, 08:18:08 AM
MBM
Your Benevolence is getting a bit "strong",Naudlin has been doing this a long time,I don't think he's a hotplate salesman looking to "score" a big month.
The Recent Mix is even more interesting ATM .
Thx
Chet
Sorry about that - I just think that measurement isn't taken seriously by a lot of people.
Power meters range from kill-a-watt devices which make assumptions about the devices connected to it based on the law - they also range up to many thousands which can measure way beyond 50/60Hz and are more accurate.
The hob is probably a chopper in the region of kHz and doesn't seem to show and PFC components on the video (they could be there mind you?).
The difference between professional test gear and a $10 kill-a-watt is enormous. Given the (optimistic) specs of the KAW I would guess (haven't calced) that, when accumulated, the errors on voltage measurement, current measurement, rounding errors in the math (this is a small uC in it!), timing errors when looking for zero crossings etc you could easily get to some double figure uncertainties (%).
For someone 'on the verge of a world changer' a few k for a decent power meter should be top of the list....or hire one. I doubt that a KAW could measure too many harmonic frequencies although I will buy one on eBay and teardown - the online specs are laughable.
If he has measured everything ok and with some finite element of doubt (say +/-10% for instance) then he should win the Nobel prize. I know that's sarcastic but if there was no measurement uncertainties then he's done it! He should get the OU prize or something.
I will tone-down the benevolence, I am sure he can figure it out :)
When... or rather "if"....  he shows massive OU from the coffeepot calorimetry test, I'll start paying much closer attention. So far, that's the best testing Jean-Louis has done yet, and it shows the expected efficiency of less than unity.
I would like to know something: When the halogen bulbs are used as the output load, is there any darkening of the glass happening? The bulbs I use for loads in my wireless power systems, operating at between 500 and 800 kHz, get very much brighter than they do with equivalent DC power, but the filaments apparently are boiling away and sputtercoating the inside of the glass with metal, that fairly quickly turns the glass black. I even see this with NE-2 neons driven with high power/high frequency. A couple of hours of operation and the bulbs can get almost opaque.
Madebymonkeys
Quote from: TinselKoala on January 12, 2013, 04:10:54 PM
If the halogen lights are run lower than 250geg C glass temperature the tungsten bromide will stick to the glass causing a darkening - lower temperature glass could mean running them at a voltage lower than what they were designed for (which in some OU experiments could be likely).
MBM
Hmmm.... thanks, that's interesting.... but in my systems I'm not using halogen bulbs, I am using ordinary incandescent automotive dome and instrument lights, and NE-2s. And I am driving them at higher peak voltages than their nominal ratings. For example, one type of bulb that I use a lot is a car dome light bulb, Osram K5618, rated 12 V 10 W, and my wireless receiver drives it with a nice 800 kHz sine wave at a p-p voltage of around 40 volts. It gets _very_ bright, but the glass is visibly darkened after only tens of minutes runtime.
