I have a working free energy device
Started by one_christian_warrior, January 05, 2013, 03:20:51 PM
that_prophet
Quote from: memoryman on April 17, 2014, 03:34:22 PM
energy can neither be created nor destroyed. If you can demonstrate otherwise, you deserve a Nobel prize.
Energy multiplication/magnification is equivalent to creation, so that can not be done either.
All you do is increase the speed and simultaneously decreased the torque, resulting in the same power (minus the losses).
FREE ENERGY HAS BEEN FOUND
http://free-energy.yolasite.com/
   Yes, that is correct, Free Energy has been discovered, this electricity multiplier mechanism is dirt simple, and extremely easy to build, with spare parts even. Building this type of free energy device is not only easy, but is simple also, costing practically nothing to produce. This is mainly because you are able to build this contraption with spare parts, and very few parts at that.
   This device is extremely easy to build, with only a few moving parts, such as at least two pulleys, one large pulley, one or many small pulleys, and a belt, strap, rope or even string in a pinch, to connect the two pulleys together. There are only two more moving parts here, a DC drive motor, and at least one AC output motor/generator. I say at least one, as you could have many more, as the more generators you have, the greater the multiplication factor of your electricity multiplier unit. You can also increase your multiplication factor by increasing the circumference of your drive pulley, or decreasing the circumference of the output pulleys.
   The workings of this miraculous mechanism are pretty straightforward, and can be described by using a multiplication factor of rotations, by merely changing the size of pulleys. You put an extremely small amount of DC electricity into the drive motor, which has a 100cm circumference and only needs to do one single revolution. This drive pulley is connected to at least one one-centimetre circumference mini-pulley that acts as an output device, giving us 100 units of AC electricity, per every output pulley that is connected.
   I suppose that you might be able to see how this could start adding up, giving you 100 units of AC electricity for every output mini-pulley that you attach to the system. If you only added 10 of these mini-pulleys, then you would gain 1000 units of AC electricity, for every single input revolution of the DC motor that you put into this free energy device, otherwise known as GEM = Geometric Electricity Multiplier
[/quote]
·   THIS DOES WORK !!!
It just takes you to look past the lie,
That evil forces are whispering in your ear,
It is pure logic, that pulleys multiply rotations,
+ with AC electricity, revolutions equal AC power,
Satan hides this super simple free energy technology,
By immediately bringing up torque needed to rotate pulley,
Letting you forget AC motors are a breeze to rotate,
You could easily have 10 – 100 of them rotating at once,
And when the drag of load attacks, it is minimized by 1/10th to 1/100th,
Because of it getting divided up, so it lessens it so severely, that it works
Please believe me, and my Lord + Savior, Jesus Christ,,,
God So Much Wants to Give us this Little Miracle Device,
+ He only ask for your faith,,,
And Yet Another thread spammed by this liar hypocrite.
IT DOES NOT WORK. Go ahead, prove me wrong. You cannot, because.... IT DOESN'T WORK and nobody is falling for your spam.
MarkE
Quote from: that_prophet on April 17, 2015, 02:32:22 PM
God So Much Wants to Give us this Little Miraculous Device,
Then demonstrate it.  You won't for the simple reason that it does not work.
Brian516
that_prophet
Quote from: MarkE on April 18, 2015, 07:46:44 PM
yes, I have a working model
anyone could have  a working model
if they have an electric wheelchair
with the settings turned up to max power + max speed
then if they go up hill at max speed
+ then back down hill at slow speed
they will gain the power to go further up the hill every time
they repeat their test of up + down hills
this was how I proved that it works to myself
Free Energy made simple = electricity multiplier using 100cm to 1cm pulleys
Don't believe in God or good + evil forces
Free Energy is so simple,,, that it MUST be hidden by evil forces.
It is simplicity at its best; you simple put the minimal power into a DC motor with a 100cm pulley connected to it, which only has to rotate the once. This large pulley is connected to a belt, strap, rope or even string in a pinch, which is also connected to another small one cm pulley, which rotates 100 times. So you put in the DC power to rotate your input motor only the once, and you get out of this system 100 cycles of AC power. You have just created your first free energy machine, that multiplied your electricity by 50 or 100. If anybody starts complaining about torque being a problem, just think about how smoothly bearings are nowadays, as well as how easily electric motors rotate. You could add ten of these small pulleys, without gaining any sufficient torque, giving you a 1000 power electricity multiplier.
A drawing and better description of how this works is at:
Please believe me + not all of the evil spirits
That are continuously saying, "this won't work"
I happen to be struggling with an electronic simulator at the moment,
trying to get a working model of this awesome free energy machine that God Shared
I believe that He wishes for this to be priority for me,
it is so simple, and easy to build,
could I ask for help getting a working model of this device out to the world,
evil forces have put up barriers for me at every turn,,,,,,,,,,,,,,,,,
THIS WORKS, IT IS SO SIMPLE THAT IT HAS TO WORK
this device generates AC electricity by using mechanics of varying pulley sizes
to multiply rotations,
generated additional AC electricity by using multiple generators
Free energy is super simple
It has been staring us right in the face
Ever since we discovered how to make AC electricity
How is AC electricity made?
It is simply made by rotating wheels or pulleys
With these wheels connected to an AC motor
Which is easily created, by using a few coils of wires
And rotating them within the field of two opposing magnets
They will try to say what about torque
Torque is not a problem in the slightest,
As electric motors are the easiest to rotate
They have some of the smoothest running bearings
So you could add tens, maybe even hundreds
Of these AC motors, attached to mini pulleys of one cm circumference
On the same belt that you have a DC motor attached to as a drive motor
With a large 100 cm circumference pulley or even larger
So you only have to input enough electricity to rotate the drive motor one rotation
Then you get 100 cycles of AC electricity out of this system
For every mini pulley with an AC motor attached that you connect to the belt
