The Primer Fields - Breakthrough in our understanding of magnetism
Started by Benevolent, January 06, 2013, 01:55:42 PM
Qwert
The colors of the domes on the video are somewhat misleading: they should be painted two colors, just like regular magnet; the inside of the dome should have different color from outside.
It could be from this concept:
http://www.youtube.com/watch?v=LyvfDzRLsiU
gravityblock
gravityblock
A magnetic dipole are not two particles (North/South), but are more one entity.  Below is an interesting comic posted by Broli in another thread in a topic on magnetic fields.  I modified his original comic by adding an image to box #6.
According to David LaPointe, "the bowls emit a magnetic field that controls the plasma. The electricity does not make the fields, nor cause the formations therein. The formations are there all along with or without electricity".
Gravock
vrand
Quote from: gravityblock on February 03, 2013, 04:04:57 PM
PF 3 will be released on February 7.
Gravock
Thank you for the update, looking forward to seeing it and eventually the free energy device based on this technology!
Cheers
Gravityblock:
Based on what I observed in the first clip, it looks like each half-hemisphere (I'll call them bowls) is just a magnet with a funny shape.
It looks to me like he took the two bowls and put them in a magnetizer.  Let's assume that you have a magnetizer that has a horizontal surface that you can place the bowls on.  Let's assume that the magnetizer generates a very strong magnetic field in the vertical direction.
You put the first bowl in the magnetizer and push the button.  The result is a bowl with the top half the north side and the bottom half the south side.   Then you put the second bowl in the magnetizer, but this time the bowl is upside-down.  You push the button and this time you get a bowl with the top half the south side and the bottom half the north side.
So if you were following his colour scheme convention, the reality is that one bowl is top-red bottom-blue and the other bowl is top-blue bottom-red.
When you magnetize the bowls the resultant magnetic lines of flux inside the bowl material will tend to follow the curvature of the shape of the bowl.  This is because during the magnetizing process the magnetic lines of flux will tend to follow the path with the highest permeability.
So the author of the clip is playing with strangely shaped magnets inside a partial vacuum where two high-voltage electrodes are generating plasma.
