Free Solid State/mechanical energy
Started by KSW, April 13, 2005, 06:59:25 PM
allcanadian
Quote:
When we transform the form of that which we removed into its opposite we can place as much of this back into our source as we desire, limited only by the capacity of the source.  This is lesson one!
Does this have any relevance to the teslas radiant energy collector?
A while ago I was thinking this, that an inductor could be charged with Emf, then seperated from the circuit and put in series with a (+)capacitance(plate up high) and a Ground plate, the Bemf returns to source but also drags in atmospheric charge  into a capacitor, then repeate the cycle. I keep thinking that external energy has to be moved into a system without work .
Can the higher potential Bemf above the source potential be used to move charge into the system?
By the way I like what your saying. It is a lot easier to understand whats happening when you lose the mainstream terminology, it puts things in a better perspective.
Charlie_V
Erfinder,
Thank you for answering my previous question about the magnetic ring.  I have two more questions.
Since the magnetic ring does not effect how the circuit functions, why do we need a specific number of magnets (or any magnets at all)?  How would the octave equations change if you removed the magnetic ring?
Again,
Thanks!
P.S. Just call me Charlie
barbosi
Quote from: Erfinder on February 27, 2007, 05:20:21 PM
Hello,
This should have been obvious!  The primary coils are connected in series.  The secondary coils are connected in series.  One positive pole of the primary and secondary coils are connected in parallel.  An EMF leaves the battery and is not allowed to return.   Many of you are going to argue this and say that the current returns to the battery via the secondary winding.  You would be wrong!  Why?  1. Refer to quotes from Tesla patents back on page 7.  2.  Currents behave differently when they are pulsed!  Study how they behave, how they flow.
I'm OK substituting "electric current" ("electron flow") with term and concept EMF. Also with science explaining and describing in great detail only half of the process (how current/EMF returns to source)
However, I have trouble understanding the process described here within a time diagram.
Since this device is designed to explain, here is what I understand and please correct me where I'm not seeinng the right thing:
Condition: assuming we don't know what the rotor is going to do, lets say we are manually operating the switch between ON and OFF position.
1. At t=t(0), the switch is ON. At this timeEMF from batery flows through secondaries and HAS the return path back to battery. Unless is switched back OFF before the "current" starts to flow. In this last situation the ON duration should be extremely short. The lenght of the wire is 144*22.5*4=12960 mm (almost 130 m). Now, at the speed of EMF (...?...) you do the math. Bottom line, it has to be a significant period of time with the switch ON when EMF flows in the circuit and return to the battery via secondary circuit.
2. At t=t(1), the switch goes OFF. Here I can see the rupture, the EMF is not allowed to rush at the same presure back to batery, The presure decreases and we have the cavitation like fenomenon. Here happens a lot of things which will be analysed later,...
3. At t=t(2) the switch goes again ON, we don't know yet what are the efects of previous state, but essentially the process restarts again like at point 1.
Are there any flaws in my logic so far? I would like to walk on solid ground based on consensus, before analysing the next.
Regards.
PS: Lets analyze the capacitor's role later as well.
When the Power of Love overcomes the Love of Power, there will be peace.
Grumpy
quick recap:
QuoteThe BACK EMF FIELD.  THE FIELD OF DREAMS!!!!!
EMF = PARAMAGNETISM
BEMF = DIAMAGNETISM
Quote"Positive charge attracts positive charge and expels negative discharge.  Negative discharge repels both negative discharge and positive charge."
Analogy:
EMF (paramagnetism) attracts EMF (paramagnetism) and expels BEMF (diamagnetism).
BEMF (diamagnetism) repels both EMF (paramagnetism) and BEMF (diamagnetism)
Will add more in a minute...
EDIT:
The Radial Universe
The entire mechanical principal of Nature, by means of which its light illusions of motion are produced, is the consequent effect of such radial extensions. Because of it, the seeming multiplication and division of the universal equilibrium into the opposed electrical pressures of gravitation and radiation, which form the foundation of this universe of change, are made possible.
        -Frank Edwards
barbosi
OK, since electrons do not exist,  electric current is a missinterpretation, please explain what is EMF and what is BEMF.
Thanks.
