Free Solid State/mechanical energy
Started by KSW, April 13, 2005, 06:59:25 PM
Charlie_V
You know, I told you guys long ago and even posted an image on how to make this magnetic ring void.  No one listens to me.  I told you that a hard drive magnet would not "void" the polls and that an axially aligned magnets put in a shape of a ring would.  You don't need special magnets to do this.
I know this because in my early days of experimenting with magnets I made a ring out of 150 magnets rectangle magnets, each with a piece of plastic on one side (so that they gradually arched).  The magnets were 3/4" x 1/2" x 1/4" N48 neodymium, so a ring of 150 of them was quite huge - probably around 1.5 feet in diameter.  When I closed the gap, I found that there was no visible field anymore.  Metal would not stick to them.  The flux was completely contained within the ring.  Unfortunately the ring didn't serve the initial goal I was going for and I took it apart.  I wish I had experimented a little more with it, seeing what would happen if you placed a magnet on the outside, if it would appose or attract or do nothing.
I still have the magnets but not the time to set up the ring (took me two days to do that).  Besides, I've come up with other ideas with magnets to work on.  I have discovered that if you are going to do anything practical with magnets and coils (just magnets and coils) you need to find ways to alter the magnet's field.  A static field is no good and will never yield a thing.  You want something in your system changing.  Like I always say, a magnet is in constant static motion.  They don't give like a battery, they share.  Anyway, Erfinder's motor thingy should work.  You guys need to just build it - I would build it but I don't have the time.
I disagree with Erfinder on one matter, perpetual motion is not fake, but it should be called perpetual work.  The fields that are magnets make up everything, they are infinite in nature.  They are like rings, they have no beginning and no end, they simply circle in constant motion.  We give them labels such as "north pole" and "south pole" and "void" but they are really just a single entity - I call it kinetic energy.  They are the kinetic side of the universe (the electric field is the potential side and matter is what flows between them).  God placed energy into this universe, and this energy swings back and forth like a pendulum without friction.  A unity device would convert 100% of the energy placed on it to work.  In the end however, this energy is used up.  An over unity device actually puts back the energy into the system, thus doing work yet returning the energy it used.  Magnets are the key, how you change their field is the solution.
Charlie_V
One quick thing about the harmonic modes.  At work I was experimenting with acoustic resonators - both quarter wavelength and half wavelength.  Something I noticed, and you can do this with the math, in both half wavelength and quarter wavelength harmonic cycles, the 3^n "octave" modes appear.  However, standard 2^n octave modes are only present in half wavelength resonators.
I also saw that the 3^n modes in my quarter wavelength glass resonators were stronger than the regular harmonics not at 3^n.  This was pretty interesting.
nat1971a
Hi All,
I thought I would share my thoughts about what happens when 2 vortexes (or 2 of ERFINDERS magnet rings) are running in opposite directions.
So lets imagine a magnet ring (ERFINDERS) of NSNSNSNS runs clockwise at light speed. Lets also imagine another vortex (another magnet ring configured SNSNSNSN) running counter clockwise also at light speed. What is the effect of this?
Well i did some research into antigravity (or levitation) a few years back and apparently if you could configure two vortexes running in opposite directions it would produce levitation (or antigravity). How accurate this information is, is anybodys guess.
Heres a reference i found......but there are many more
"If a second arrangement of spinning magnets, or a spinning magnetic
disc, is coupled to the first, but arranged to spin in the opposite direction, the two opposing magnetic vortices will set up an anti-gravity force."
http://anina.typepad.com/anina/2005/07/vortexes.html
Nat
nat1971a
hmmm I wonder what 3 magnet rings does.....................
nat1971a
RE:
Sit back and relax take in a deep breath and exhale it slowly, and think about what Tesla could have meant when he said closed on themselves referring to the coils in patent no. 464,666).  If you get stuck, as I am sure you might, go pay Ed Leedskalnin a quick visit.  Study his Perpetual Motion Holder, closed upon themselves indeed!!!
hmmm i am starting to think that the core was a ring of iron.
