Free Solid State/mechanical energy
Started by KSW, April 13, 2005, 06:59:25 PM
barbosi
RE-EDITED: To maintain a dialog, debate, around the subject.
I think I have an advantage here being "electric machines" blind so I try to understand the works.
I hope it will help others who knows and might be temped to answer by reflex. So bear with me and curse if you like, but make me understand.
Please consider me -if you wish- the "dumb factor" in a brainstorming session.
Questions:
1. First I would like to see if this motor woks at all, without secondaries F & G. Mmm? I see how it would work with magnets instead of rotor coils D. North South alternating on circumference, and magnet's poles distributed radially (like in Bedini's window motor). But with present coils...?
Quote from: Charlie_V on April 26, 2007, 12:19:34 PM
... You put the current 90 degrees out of phase between the primary and secondary.
2. How exactly?
3. Is it important +90 or -90 degrees? Why?
... You make sure the self inductance of the secondary is neutralized by placing a "condenser" (capacitor) in the secondary circuit.
4. Why?
5. Is not affecting the main goal with 90 degree phase shift from primary? Why?
... This increases the current in the secondary.
6. If you answered "resonance" at question #4, then why current and not voltage?
... The current makes the rotor spin.
7. How?
... Since the phase between the primary and secondary is 90 degrees, power used is returned.
8. Why?
... The device runs on unity.
9. Why?
Don't believe in lizard people.
Anyone who can convince me without fancy names and theories will be filtered out as non lizard people. If you can, use the association of electricity with water flowing in pipes. Please assume you are a science teacher; can you explain this to a child?
Regards.
When the Power of Love overcomes the Love of Power, there will be peace.
barbosi
Quote from: bocas on April 26, 2007, 01:52:45 PM
... If Erfinder?s secondary length of 144 inches @ 22.5 mm /inch is used, which is the harmonic of 432, which is the square root of the true speed of light, maybe it is resonant with the speed of light. ??  ...
Another legitimate question (if you got that far):
432^2 = 186624 the "true light sped".
Is the 186624 miles/sec @ 22.5mm/inch too?
EDIT: I mean why don't we use the metric system, or call 1inch @ 22.5mm = 1 propagon and to others other names? Did ancients use other names for this? Why just don't adopt them?
nat1971a
Hi all,
I think Charlie_V's description is a good starting point. But I suspect a few things need to be added to it or expanded upon. e.g the relationship b/w the armature coils & the secondary closed circuit.
N.
nat1971a
I suspect that because the armature coils are neutralised & the secondary (working circuit) is neutralised there is a transfer of neutralised current from the armature coil ,as well, to the secondary closed circuit that is neutralised.
Well thats my imagination at it again.......
Any comments ERFINDER?
barbosi
Quote from: nat1971a on April 26, 2007, 06:56:12 PM
So if you launch a neutralized chicken over the fence, it will make a neutralized chicken too. and later if you launch it back at the origin, this one will make a neutralised chicken again.
Come on people! just figure we are all sitting relaxed at the same table having a beer. This is how you talk?
I just admitted I'm dumb. I apologize if I offend anyone with my intellectual abilities, but please don't offend me making me feel more dumb than I really am.
I think the politically correctness is the problem here. Just express yourselves.
