Free Solid State/mechanical energy
Started by KSW, April 13, 2005, 06:59:25 PM
louis
@bocas
i will get as much detail together as i can for you, and post it later
bocas
For those of who don't follow other threads on this forum here is a translation done by Gustav22.
http://www.overunity.com/index.php/topic,2235.msg32290.html#msg32290
Thanks Gustav22 and Otto
Charlie_V
louis,
How are you determining that there is no magnetic field?  Do you have a Gauss meter to measure the field in the vicinity of the coils?  I assure you there should be a magnetic field if there is moving charge.  However, depending on the frequency, the field may be very fast and very large in the secondary.  If there really is no field, then this is a very interesting find!
Grumpy
There is no magnetic field, but I bet there is a tempic field.
Do you feel a sense of "pressure" with your hand?
        -Frank Edwards
louis
to detect magnetic field i use a very small neo magnet, can usually feel magentic field.
circuit description.
12 battery ( + )connected to a huge coil ( simulating motor windings )
which is 740 metres of size 30 awg enamelled copper wire.
coil resistance is 259.2 ohms.
other end of huge coil connects to com terminal of relay.
n/o connection of relay connects to ground ( - ) of battery.
connect also com of relay contact to primary of erfinders coil,
other end of primary goes to 1 nano farad capacitor ( 15 kv )
farnell part no 969-7470, other end of cap goes to n/o contact of relay.
relay driven by 556 timer set at 45.454545 cycles per sec.
primary of erfinders coil ( bifilar wound) 22swg copper enamelled wire
46 cm long. secondary of erfinders coil is 3240 mm of the 30 awg wire.
resistance of secondary is 1.075 ohm, resistance of primary is 0.1 ohm.
get approx 100 turns on my former for the primary. approx 10 turns for secoondary.
any how heres some pictures i just took,
