desulfator infinitum
Started by dragonx, March 19, 2013, 12:42:59 PM
gyulasun
Hi,
Here it is
1 quantity  2N3055 npn transistor
1 quantity 330 Ohm resistor 1/2 Watt
1 quantity 1 kOhm variable resistor or potmeter
3 quantity UF4007 diode
1 quantity  toroidal ferrite core OD 12mm to 25mm
IF you do not have a wall plug-in mains power supply with 15V or 18V DC output you also need such. OR if you have a mains transformer with 12-15V AC output, max 500mA load current it is also good, for this latter you need rectifiers:
4 quantity 1N4007 diode
1 quantity 1000 uF /35V DC electrolytic capacitor
dragonx
Quote from: gyulasun on March 21, 2013, 10:13:03 AM
Hi,
Here it is
Thank you very much I think do have old power supply Pc & will find few more old wall plug
dragonx
Quote from: dragonx on March 21, 2013, 03:26:50 PM
can you give me link parts all is digskey .. cuz there too many number diffence just wanted to make sure right you know what i mean? :P.
i found core on broke tv lcd i think
gyulasun
Hi,
1 quantity  2N3055 npn transistor  http://www.digikey.com/product-detail/en/2N3055/497-2612-ND/603637
1 quantity 330 Ohm resistor 1/4 Watt  http://www.digikey.com/product-detail/en/2-1625875-6/A105936CT-ND/3477500
1 quantity 1 kOhm variable resistor http://www.digikey.com/product-detail/en/93R1A-R22-A10L/93R1A-R22-A10L-ND/2564718
3 quantity UF4007 diode http://www.digikey.com/product-detail/en/UF4007/UF4007CT-ND/965732
Should you not find toroidal ferrite core, here it is:
1 quantity  toroidal ferrite core OD 20mm http://www.digikey.com/product-detail/en/B64290L0632X830/495-3864-ND/1830194
Should you have no wall plug-in mains DC supply but with 12V-18V AC output only, you need these to rectify AC output:
4 quantity 1N4007 diode  http://www.digikey.com/product-detail/en/1N4007/1N4007FSCT-ND/965481
1 quantity 1000 uF /35V DC electrolytic capacitor http://www.digikey.com/product-detail/en/ESY108M035AL4AA/399-6120-ND/2712532
OF course you need enamelled copper wire to wind about 30 turns bifilarly onto the toroidal core, roughly at least 2 meter in length, wire diameter could be anything from 0.3mm to 0.6mm  (roughly awg #29 to #22).
(You may also try this as I indicated earlier:  http://www.goldmine-elec-products.com/prodinfo.asp?number=G16214 )
good luck.
dragonx
Quote from: gyulasun on March 23, 2013, 02:56:20 PM
Hi,
good luck.
is there any website it give free shipping? . i ordered digikey & fee shipping.. total $14
