Magnet Motor that works
Started by gotoluc, March 24, 2013, 03:07:18 PM
DreamThinkBuild
Hi MileHigh,
QuoteTito, do you think the clip you linked to with the magnet motor on the rectangular metal plate, "!!! Free Energy Demo #2 Magnet motor.mp4", is real?
Don't know if that motor is real, but did dig around to see how consistent it was.
There are some other videos of it and it always rotates the same way consistently when the bar is placed at maybe a 35-45 degree angle at certain distance marked by a spot on the plate. The rotor seems to always rotates towards the facing angle of the bar.
http://www.youtube.com/watch?v=T6MCBOnYqmo
http://www.youtube.com/watch?v=Maf61RwvIMk
The spacing of the magnets seemed odd on the rotor, so I had to look at them a little closer (pic attached).
My thoughts are the arrangement on the bar is creating a U shaped field of attraction and repulsion the middle magnets on top control the shape of the break between the two fields, if they were not there I could see the two fields create a sharp dividing wall like V creating a gate. The small magnets push it into a U curve.
I could be wrong though, the thing that throws me off on this motor is how it starts seems odd. It doesn't seem like perfect alignment is necessary(?) or as others state something else is driving it.
JouleSeeker
Quote from: DreamThinkBuild on March 29, 2013, 12:45:40 AM
Hi MileHigh,
Thanks for the effort and analysis you've put into this, DTB.
1.  Did he use neo-magnets?
2.  Any idea of the orientations of the magnets?
3.   Are you considering a build?
4.  Any comments on the Yildiz motor?
Gwandau
How on earth does people expect us to accept video clips like these.
To present a novel invention of this magnitude calls for full transparency, these clips just makes you upset and sad, it's actually like they are made just to annoy you.
In my opinion anything deviating from the criteria below STINKS.
1. The active components of the construct has to be assembled on transparent glass, plastic or polycarbonate.
2. Experiment must be performed upon a completely transparent table, at least three feet from ground level.
3. Absolutely essential is a minimum of three feet visible free spacing around the table.
Following these rules allow any scientifically schooled mind to initiate a certain amount of interest. Still such a video is no proof whatsoever, just an indication that it may be worth executing a validation.
Any deviation from the above criteria makes any theoretic speculation totally uninteresting since the video inevitably has to be considered as fake.
Gwandau
Magluvin
Quote from: Gwandau on March 29, 2013, 06:25:18 PM
Well, I wouldnt dismiss anything just because it wasnt presented as you require. The person posting the vid may not be aware of these technicalities required by others.
And Im sure once its viewed by others that require the requirement, the poster can redo, as required or not. Other than that, replications or an on scene investigation would be 'required' beyond any video. If you are familiar with the Mylow saga, once the 'tricks' were carefully identified as to how he kept the wheel turning, anyone would be a bit surprised that someone didnt catch it earlier as some of it was right before our eyes and we didnt see it. At least until someone took the initiative to really look for things, and there they were, along with a confession.  ;)
Mylow was a magician of sorts. He had a bit of talent like keeping your attention on portions of the wheel where the stators were, while using his hand, out of view, to move the wheel. Once we 'required' him to show full views, he had problems keeping it going. So he used fishing line and motors to pull off the feat, with good success, for a while.
So dont dismiss anything that you cannot 'clearly' see and understand what type of device it is and how it works. Like the vid presented in the first post. Many here can identify the type as a SMOT. Thats what it is. Now whether the maker intends to fool people or not, depends on his willingness to answer questions and/ or provide vids of certain tests requests from others.  For me, it is not necessary, as I can identify it as a smot, pretty much immediately. For those that dont know the SMOT, YT is loaded with them. Then it becomes clear what this guy has.  ;)
Some other magnet motor vids are not easily figured out nor identified for type. These should not be dismissed in the least. But if it is not clear as to how it is made and the presenter aint talkin, well, how long should one pursue? Not saying to ditch it, but probably the best thing is to keep tabs and dont waste too much time if things dont develop further. ;)
Mags
bartguy98
Regarding a magnet motor that "Appears" to work, you might want to check out this video!  I was impressed!
http://www.youtube.com/watch?v=lZwE-uMLg2o
