I Cube Transformer
Started by icorex11, March 26, 2013, 09:47:25 AM
icorex11
so if we notice in the schem  that it is stable 24vdc @ 5amp   input!   so thats great then .....  as i said this is designed to charge ULTRA BOOST CAPS ...
it involves only a small selection of parts  its simple to build and easy to repair  should that ever be a problem ..  the secondaries are rectified via full wave high freq rectifier diodes ... ie. MICROWAVE DIODES and i have a small collection of them but there not forsale !
aswell i have a production  rectifier to suit the need!
as for a power supply it could be what ever you desire  a battery .. a cap ..  or  any number of other sources .. as long as its dc
a pot can be placed in there aswell to vary the freq..
but it will work fine as presented !
ARX11
icorex11
in this picture you see the basic coil fully wound  primary trigger secondaries even at 1 vdc / turn i will get 60 volts plus  x 4  but i expect to get a bit more ....
i could wind more secondaries on those cores or a multi layer secondary but for this design i already have more than i need  i may wind ontop of this yet a thick wire high current secondary and just use those 4 showen for incecdecent light bulbs or robot motors or something ... lol
ARX11
icorex11
now for the power supply i will use to power this transformer  i was planing on useing  a laptop power supply  the output of it is 19vdc 4 amp i do have quite a few laptop power supplys i will sell them at $30 cdn each  this adaptor can be powered from a 12vdc source if useing a invertor  so thats kool...  i do like the laptop supplys for reasons i have devised in the past  output of the avarage power supply is about 50 - 100 watts  thats a great amount of supply energy to this device  but i could run 1000 wats should i desire .....
i do have many other inventions that operate and are built with recycled materials  like the ARX11 it can handel many kw ...  but im not here to build a invention that will only be stolen in the end ...  the concept is simple .. the device is simple and why it works is also simple .. i need not explain it AGIN .. i have many times in the past ....
so  being im useing  the cores from the flybacks i have a LARGE ABUNDANCE OF FLYBACK WINDINGS ..  so thats great then ...  i also am selling them at 15$ cdn per winding and i have a invention that uses thease ALSO ..  its called the  BUCKING MAGNETIC COMPRESSION RING ...  but agin  it shall not be dicussed here  ....
ARX11
icorex11
so that prety well compleates this winding configuration  and driver    as i have said i have many configurations to winde on the ICUBE's i will be displaying a few more  ways to configure my ICUBE  cores     SOME OTHER WAYS ARE KINDA INTRESTING ...
my next design  incorprates  my spinner style teck .. and  there is 2 spinners involved in this next configuration  1 counter clockwise and the other clockwise  wound top and bottom of the ICUBE core   now the core can be seperated in the 2 halfs and the distance between the 2 varried there unlimited options with such a ICUBE  core as mine ...  the only limiting factor to createing such a number of configurations on 1 core  is ones mind ...
i have more ways to wire up this same cube core yet !
so i will start with a fresh blank ICUBE  core  and show the winding for the spinner  for the spinner i will use magnet wire
ARX11
icorex11
well here is the second ICUBE core  blank and in the second picture you see the spinner being wound on this ICUBE
the spinner is wound 1 wire 24 gage  1 turn per leg per revelution  on the 3rd picture you see the pattern that is made from winding in this spinner style configuration
ARX11
