Electricity from Neo Magnets and Bismuth - A Daniel Dingel Secret released
Started by e2matrix, April 08, 2013, 03:14:55 PM
e2matrix
Hi bolt,  Good to see you around again.   That's exactly the device (in the youtube you listed) that I mentioned above and was thinking about but I couldn't recall what it was called or the guys that built it.   Thanks for that and also the great info on bismuth which I was not aware of.  I've come across yet some other devices using it but alas the fuzzy old memory doesn't recall the other ones yet.   I've got some bismuth and will be trying some experiments.   The last I recall (IIRC) you were working on running a generator with HHO.   How has that been going?  Cheers
bolt
I still got the HHO generator i learnt a lot about making the software etc for spark blanking etc but the results for looping i could not make it run for more than a few seconds on pure HHO...not enough capacity from my 21 plate cell.  Anyways,  I found the best and by far the most economical thing to do with these gasoline gensets is convert to Nat gas then use HHO injection improves economy by about another 20%-25%.  Its now very competitive  with grid prices per kWh.
So i have this genset available for my "end-of-the-world"  emergency back up system:)
Regarding this bismuth energy i knew i seen this before it took me a while to think of the device but there are many other materials than can be used. I seen mention in other free energy devices of lithium, cadmium, calcium, iron, cobalt, zinc, copper,  etc but its interesting that bismuth having atomic number 83 is one heavier than lead and one less than polonium.  They all seemingly are NMR sensitive enough to convert to isotopes and release huge amounts of energy.  It also now looks like Kapaandze is most likely to use atomic device and so is the TPU. If so Steven mark used copper and converted that to an isotope. You need 2 RF frequencies, One shifts the procession spin to 45 degrees in the X plane and the other has to bang it back as fast as possible 45 degrees Y plane  without relaxation causes it to funnel into a spin vortex. This is why pretty much all these devices have control coils in X  and Y planes. Z plane can be substituted for the local powerful magnetic field using neo magnets.
Remember also Steven Mark said "you will get something out of it with one correct frequency  but you will raise hell Mary if you get both correct" at the right amplitude in the presence of the required magnetic field of least 1 Tesla.
e2matrix
Thanks for the additional info.   I guess we were thinking alike on generators.  I got a natural gas conversion kit for my generator too.  I still have some setup work to do on it but I plan on setting it up inside the garage with piping to the outside for a full size car muffler to make it quiet.  I'll build a small 'dog house' around the muffler with bare fiberglass insulation inside and expect it to be almost completely silent with that setup to anyone not very close by.    One thing I haven't checked into in regards to that is whether NG in this area is independent of any need for electricity (pumps?) to get it to residences.   I would guess the natural gas suppliers though probably have their own NG gensets to keep power going in case of grid failure.   Probably answered my own question on that ;)
The Architect
Quote from: e2matrix on April 11, 2013, 02:22:29 PM
Nice find!   Thanks for the info on that.    As I've got a chemistry background I can see it as being something not that hard to do although I don't have some  of the lab equipment like magnetic stirrers or a centrifuge.   If there was a market for this stuff you could certainly make some money making your own.  I did verify an online company selling 10 grams for 845 Euros!   (That's about 1,109 U.S. dollars for about 1/3 ounce - more than the cost of gold! ).    I believe he said it cost him about 50 pence to make his 10 grams and 50 pence = 77 cents.  Quite a profit margin some company is making there.   I wonder how much hydrogen per minute can be generated with this as a catalyst?
you should look around at his videos, I know he has at least one that shows how to make a magnetic stirrer on the cheap. I have a bunch of hard drives I tore apart for the magnets of course, and started leaving the circuit and base in tact, so now I have about 12 motors that just hooking up a PC powersupply gives me a working 7200RPM motor, and I am betting that would work easily for a small centrifuge and decent size stirrer :)
http://www.youtube.com/watch?v=pW8ah9tBiWQ
I do not mean to keep posting his videos, but these are some of the best howto videos I have seen so far on the net period, I am definitely going to grab them all and get a copy of his book on graphene just for reference, at the very least. :) I will look around and see if I can find his one for a centrifuge and post it too, as well as I am going to build a 555 timer circuit to control my PC powersupply to keep the motor spinning indefinitely on some of my hard drive motors (some spin for a short time stop then spin again doing this cycle indefinitely with out being tampered with, while others will spin for well over a minute then stop and you have to shut the power off and on to restart it, so that is what the 555 timer is going to be for, to run a relay that disconnects the power about once every minute :) )
