Big try at gravity wheel
Started by nfeijo, May 03, 2013, 10:03:04 AM
MarkE
Quote from: TinselKoala on February 21, 2014, 03:27:06 PM
Demonstration of overunity requires precision to the billionth part of a cubic centimeter? No wonder we mortal fools can't do it.
One would think that Mister Wayne Travis could, with all that fancy apparatus he's got, show some actual measurements that indicate some kind of OU performance, on an actual diagram --- once he's met his own challenge and actually _defined_ what he means by that term himself.
Like I did. I showed how a small weight, dropping a certain distance, can raise up a much larger weight _the same distance_ in the same time interval, thus producing a 200 percent efficiency level, a COP of 2.... a clearly OVERUNITY result, using only a simple no-layer system that is clearly overunity by itself, since its output work is twice the input work.
Right?
Who knew that simple "U" tubes were over unity devices?
Grimer
Quote from: mrwayne on February 21, 2014, 09:41:00 AM
No Takers to learn the system?
Just more spit.
OK - work is done here.
To RED, Webby,
Let them be - we are moving up, and onward.
Wayne
I've been thinking about a hydraulic system in terms of the Keenie.
The essential functions of the Keenie are a spring and a valve. In the case of a hydraulic system a confined quantity of air could provide the spring and a valve would be no problem.
So I see no reason why the kind of thing you are proposing could not work because the Keenie certainly can.
Who is she that cometh forth as the morning rising  -  Fair as the moon. Bright as the sun  -  Terrible as an army set in battle array.
No, it certainly cannot, and you cannot provide any evidence for your claim.
minnie
Hi,
     looking at Wayne's  5hp. unity there's no way it's gravity powered. If the whole thing is
  in the 7ft by 10ft size as he says will allow cylinders about 3ft diam x 6ft height .
     This will give about 2500lbs (water ?) and say a stroke of 2ft and he kindly admits
   to 3 rpm. This gives six power strokes per min. and if we can use all the weight we
   get 2x6x2500=30,000 ft lbs. min.
      What we're looking for is 5x550x60 = 165,000 ft lbs min. so we're about 135,00
    ft lbs short. This means that the thing is working at a huge pressure and the question
    is what generates this huge pressure?
                                  John.
MarkE
Quote from: minnie on February 22, 2014, 07:56:06 AM
Hi,
                                  John.
Wayne Travis likes to talk about nameless engineers who supposedly back his false claims.  We never see any statements from any professional engineers, or any engineers for that matter.  Investors who rely upon statements by professional engineers can sue if the statements are negligent.
