Finally! Independent Testing Of Rossi's E-Cat Cold Fusion Device. Success?
Started by rukiddingme, May 21, 2013, 12:06:50 AM
profitis
@mark E the rossi effect is a quantum 2lot violator much like a quenco or habtech is supposed to be.nuke events are a side-effect,usually endothermic disintergration taking place.if you stop heating a habtech you stop getting your excess power.if you drop below a certain temperature due to dissipation,your ecat drops dead.it needs to be fed at interval times.
profitis
if your nuke side-effect goes exothermic instead of endothermic,then you can remove the mouse..but you better have a damn good coolant system going or a meltdown is likely in that scenario
MarkE
Quote from: profitis on October 13, 2014, 10:39:39 AM
You are not doing yourself any favors.
Philip Hardcastle has withdrawn from the scene.  He did not ever succeed in devising any experiment that demonstrates violation of any thermodynamic law.
Rossi is a charlatan who has staunchly refused to allow anyone to perform a proper measurement of input and output energy on his stage props.  Rossi has failed to establish that his devices outperform the resistance heaters that are integral to each and every one.   Rossi relies on heavy winter coats and conventional propane heaters rather than his eCat heaters during those cold winters in Bologna.
profitis
Quar is the word @mark E regardless of what rossi is using to heat his lounge..quar is the new black
profitis
Quar is going to hang around for a loooooooooooooooooooooooooooooooooooooooooooooooooooooong time to come like a gluttonous sucking parasitic leach mark E.what's the bet.quar has attatched its hooks so deep in the entrenchment that no parasiticide can kill this new fashion
