Magnet question
Started by elecar, June 02, 2013, 12:09:58 PM
ace569er
Also what I'm talking about cant not be achieved easily with a spiral design..... Unless modded to halve v-gate mini spirals. Halbach array could be used, (I think)but the V-gate is the simplest inclined configuration that works with this mod, with the best drive to sticky point ratio.
ace569er
Seance you almost more or less halve way figure out the first problem. You get the easy acknowledgement of it anyway. I'll give you a clue to the second problem. Overcoming a weaken gate, needs gravity. (I think)Now remember I stated distance is not changed so then the whole unit must tilt equally. This is not so easy, like the first issue, of a too strong sticky point, but easier than it may seem. Which is were I am stuck. At equal unity. Just pretty art...So I look to the only other thing I've seen with equal unity.
   Finsrud's device holds all the answers to that. If you think about it.(Or so I think, still testing[building]) Most of his design is just to get a 120 degree drive rotation, so that it can tilt the center & platform. Seance you already have that drive for a partial rotation in the gate. Must of his devise is not needed at all.
   Also I drew this and uploaded a 90% complete, Finsrud's device to the site awhile back. So seeing what is not needed is easy. I drew some of it wrong at the time, but that was just a quick rough sketch. I have a far better version I did more recently. Fixing several of the flaws I had in how the main shaft tilted. Plus some measurement issues. Which I can most likely upload, if I can find them.
   If you plan to build and test anything. The cheapest way to make, smallish, custom, metal parts, I found, is to 3-D print them. Then have a jeweler's rubber mold ($30), & wax cast them. Then concrete cast the wax, then pour in your hot metal. Annealing Oven it Cool, break, enjoy. Cheap metal castings.
linoavac
please , magnetical principal square/triangle is very importante
tubes:
http://www.youtube.com/watch?v=eLzyLqchwUw
if use 4(rotor)  >>>>> use 3*3*3* (multiples of 3 in STATOR)
but see photo
elecar
Very nice Linoavac, but I do not want to use any electrical components at all.
ace569er
Here's the sketch I refereed to...
