Magnet coil cores, demagnetization power and Lenz delay.
Started by synchro1, June 09, 2013, 11:07:49 AM
synchro1
A small electo-magnetic coil with backing magnets could amplify or neutralize the field strength and control the flux density of the output coil core. The flux density of the output coil core regulates the re-polarization delay and the timing of the reflected propulsion wave. This will supply continued acceleration to the rotor.
MarkE
So you think that would be the basis for a successful OU device?
synchro1
Quote from: MarkE on December 29, 2014, 10:55:18 AM
What is there to see?  It's a bridge that reverses balance when a small enough external resistor is connected.
You managed to get that much figured out on your own. Further proof you're a real Einstien!
MarkE
Quote from: synchro1 on December 29, 2014, 11:24:24 AM
The question is why are you asking people to look at your simple circuit?  What do you claim is special about it?
synchro1
The actual circuit would require two Op Amps at 15 volts and look more like this:
The first schematic is a simple continuity tester. Just a building block. This circuit connects to two transistors, as shown in TK's  video; A PNP and an NPN.
