Tragic accident with ball magnet EMDR motor-generator
Started by hartiberlin, June 22, 2013, 03:08:34 PM
synchro1
@Milehigh,
                You amount to nothing more than an over blown windbag!
You can allege that but the truth is that with a scope and a multimeter I could dissect that pulse motor and explain exactly how it works to Twinbeard.  Stage by stage, analyzing the timing, checking how well the transistor is functioning, measuring how much power is flowing and where it is flowing, properly measuring the RPM, explaining all of the impedance matching and load issues, explaining exactly what is happening with the main coil voltage and current, explaining what the "Lenz delay" really is, analyzing the power in and the power out and so on and so on.  I could dissect that motor and all the additional transformers and loads from A to Z practically with my eyes closed.
The conclusion:  Nothing special is going on.
synchro1
gauschor
So the device is nothing more than hot air? Very disappointing... I had high hopes. Though that would explain why there weren't any significant updates on their webpage since the beginnings of 2012...
synchro1
It took more then hot air to nearly cut that guys hand off. Twinbeard ended up with a darlington pair. These guys added a trio of transisters. All these setups are trigger coil bedini's. We need too hear from them about their output ratios. The video shows an illuminated light bank.
