New generator patent using environment temperature to generate power
Started by RedEagle, June 26, 2013, 01:24:04 AM
Do You Think this device will work?
Yes, definately
1 (10%)
Yes, but it needs changes
2 (20%)
not sure
4 (40%)
No, it can not work at all
3 (30%)
Total Members Voted: 10
Voting closed: June 29, 2014, 12:10:18 AM
LibreEnergia
Quote from: profitis on July 04, 2013, 10:31:53 PM
@libre..oh and i forgot,the temperature of a reflected surface can get hotter than the source.if i send 1000therms from a source at 3kelvin onto a  hotspot at 300kelvin then the hotspot bounces back only 10therms into the universe.
You are confusing temperature with heat. It's no wonder that with such an inadequate grasp of the fundamentals that you continue to come to erroneous conclusions regarding the 2nd Law.
I can hear the sounds of one hand clapping echoing back and forth across the gap, fading off into the distance.  When you can't figure things out or you made a mistake then RUN!! RUN!! RUN!!  lol
gyulasun
Quote from: MileHigh on July 04, 2013, 02:40:54 AM
Another issue worth revisiting.  You are not visualizing this properly.  The 'neutralizing of the self inductance' relates to the coil acting as a band pass filter for an AC signal.  At the resonance frequency the complex impedance will drop to zero and you will be left with just the wire resistance.
Hi MileHigh,
In the other thread http://www.overunity.com/13460/teslas-coil-for-electro-magnets/msg360645/#msg360645 I mentioned that the Tesla SBC must have several series and parallel resonant frequencies due to the distributed reactances (it is a kind of transmission line) so the complex impedance (while cancels) can be equal to the wire resistance only IF the AC input current is at a series resonant frequency. In case the AC input current matches a parallel resonant frequency, the complex impedance also cancels but the real impedance must be (Q*XL) as usual for a parallel LC tank and this real impedance must be higher than the wire resistance unless the loaded Q equals 1 and the inductive reactance value is less than the wire resistance.
Gyula
DaS Energy
Hello Sparks. You last reply well received. Not have read on Lockhead Martin. We be publishing since 2002. -10*C to +10*C oceanics needs no surface structure. Pressure variant need only need be tipping force. Liquid/Gas pressure commence at boiler pump. It turned by turbine taking force from the boiler. There is no break in the liquid force coming in and going out.  Only its phase be different. The turbine even when not in action is at constant point of rotation. Constant force starting at pump finishes at turbine entry, behind the turbine a vacuum of negative force exists. Tipping force not reduce the vacuum as the gas condense to liquid  reinstating the original liquid force being supplied by the turbine shaft. .
profitis
@libre..lets leave light alone for now because it requires us to consult the laws governing light. until you can eradicate the permanent source of emf in between 2 platinum electrodes at different depths in non-reactive electrolyte in a totaly closed isothermal system we are forced to throw out the generality of the 2nd law.
