Aether Displacement
Started by mpc755, July 01, 2013, 09:39:13 PM
kEhYo77
Quote[size=78%]Particles of matter are condensations of aether. Particles of matter exist in and displace the aether.[/size]
What if particles of matter are are less condensed with aether, then, they're not condensations but rather a lack of it.
QuoteIn aether displacement, the Earth is not expanding.
We know that stars do grow becoming red giants, why not planets? Gaining volume would be like pumping a balloon. Less and less aether inside creates stronger pressure 'gravity' from the outside.
mpc755
Quote from: kEhYo77 on July 23, 2013, 12:40:51 PM
There are people who choose to believe that. I am not one of them.
In aether displacement, particles of matter are condensations of aether. Particles of matter exist in and displace the aether. When a nuclear bomb explodes matter evaporates into aether. The evaporation is energy. Mass is conserved.
QuoteWe know that stars do grow becoming red giants, why not planets? Gaining volume would be like pumping a balloon. Less and less aether inside creates stronger pressure 'gravity' from the outside.
In aether displacement, the title of this thread, the Earth is not gaining volume. If you want to start a thread to discuss your ideas then that is what you should do.
'Quantum mechanics rule 'bent' in classic experiment'
http://www.bbc.co.uk/news/science-environment-13626587
'For his part, Professor Steinberg believes that the result reduces a limitation not on quantum physics but on physicists themselves. "I feel like we're starting to pull back a veil on what nature really is," he said. "The trouble with quantum mechanics is that while we've learned to calculate the outcomes of all sorts of experiments, we've lost much of our ability to describe what is really happening in any natural language. I think that this has really hampered our ability to make progress, to come up with new ideas and see intuitively how new systems ought to behave."'
http://www.scientificamerican.com/article.cfm?id=new-double-slit-experiment-skirts-uncertainty-principle
"Intriguingly, the trajectories closely match those predicted by an unconventional interpretation of quantum mechanics known as pilot-wave theory, in which each particle has a well-defined trajectory that takes it through one slit while the associated wave passes through both slits."
A particle physically displaces the aether. A moving particle has an associated aether displacement wave. In a double slit experiment the particle enters and exits a single slit. It is the associated  wave in the aether which passes through both. As the aether wave exits the slits it creates wave interference. As the particle exits a single slit the direction it travels is altered by the wave interference. This is the wave piloting the particle of pilot-wave theory. Strongly detecting the particle causes a loss of coherence between the particle and its associated wave in the aether.
What waves in a double slit experiment is the aether.
profitis
the 'aether' in modern physics would be the equivalent of the dirac sea or zero point theories.the reference points to paint a picture of the way the universe conserves matter-energy so-to-speak.if you poke some energy in one point of the universe,it has to pop up out another point.if you remove energy 1side,you are forced to give it the other side.when there are constraints in the shuffling of energy then weird things begin to happen,black holes,collapsing matter,shifting dimensions,particles popping out of nowhere,time-space distortions etc.. but such constraints are special.
mpc755
Quote from: profitis on July 23, 2013, 04:20:53 PM
Modern physics is so screwed up it can't even comprehend the notion the particle travels through a single slit in a double slit experiment when you don't detect it.
As far as I know the dirac sea and zero point theories do not explain gravity or what occurs physically in nature in a double slit experiment.
Aether has mass. Aether physically occupies three dimensional space. Aether is physically displaced by matter. Displaced aether pushes back and exerts inward pressure toward matter.
Displaced aether pushing back and exerting inward pressure toward matter is gravity.
A moving particle has an associated aether displacement wave. In a double slit experiment the particle travels through a single slit and the associated wave in the aether passes through both.
Q. Why is the particle always detected entering, traveling through and exiting a single slit in a double slit experiment?
A. The particle always enters, travels through and exits a single slit. It is the associated wave in the aether which passes through both.
profitis
aha @mpc..aether displacement is one of many ways to perceive reality,sure,but it might have shortcomings. an interesting test might be to shoot  electrons at a double slit and see if we get similar results to steinberg.
