Bedini, Lindemann, Bearden, Dollard -- What are their Accomplishments?
Started by Ein~+ein, July 04, 2013, 10:57:50 PM
Einstein:
I assume that you got booted from EF so welcome to OU.   There are many people on OU that were booted from EF.  You can give Stefan a lot of credit for being much more open minded than Aaron.
The original video called "Electric Motor Secrets by Peter Lindemann" was on YouTube for quite a while but Peter must have discovered that and had it taken down so I can't link to it.
I watched that video and Peter goes on and on about the "energy destroyer" inside a standard DC electric motor.  He subtracts the EMF the motor produces when you drive it like a generator, from the DC voltage you feed the motor with to make it run, and calls the voltage difference the "energy destroyer."  The premise is that there is something mysterious going on inside a conventional electric motor that is "destroying" energy.
In fact this mysterious "destroyer" voltage drop is the normal and expected voltage drop in the motor windings as the motor converts electrical energy into mechanical energy.  It is the manifestation of the "transformer" action going on in the motor: <electrical> ---> <mechanical>
So what Peter Lindemann calls the "destroyer" is actually what becomes the useful mechanical output from the motor.
And to make matters worse, this foolishness was the big inspiration for UFOPolitics and his two giant threads on EF.  UFOPolitics calls it the "Witch" and all of his funky motor rewiring schemes are supposedly to "get rid of the Witch."  All that his wiring schemes do is reduce efficiency and turn the motor into a hybrid motor/electrical transformer.  Not even the slightest whiff of free energy there.
Bedini claims a standard bar magnet has a "north half" and a "south half" and that there is a Bloch wall between the two halves.
That's completely and totally ridiculous and it's laughable that Bedini makes that nonsensical claim.
So, to answer your question, no accomplishments in the realm of producing free energy from either of them.
I don't know enough about Eric Dollard to comment.
Quote from: TheCell on July 05, 2013, 06:09:01 AM
But not related to any overunity effects, or am I missing something?
Every led has it's own resonant tank circuit .. nice.
MrClean measured more out than in.
Yes, you are missing something. Resonant tank circuits aren't new and they aren't free energy. "Measuring" more out than in isn't proving that you have more out than in, it is proving that your measurements are prone to error when there is RF, inductance, resonance, and other stuff sloshing around in your lab space. Concurrent validity is the by-word. You need to first validate your measurement methodology by measuring known UU devices and coming up with the right answer. Then you must measure your OU device with _other_ known good methodologies. Only if concurrently valid, multiple measurements using different techniques all give you the same answer, can you rely upon them for inferences.
Of course you could always self-loop your device and disconnect the battery supply.
Then you wouldn't need to make any measurements.
(Because the thing will stop running right away!!)
@ Ein~+ein.... those folks over there are whacky. Err-on doesn't seem to realize that he is communicating using a product and a system that is the pinnacle of "mainstream science".... which is really just Science, the only science there is...... and that if it weren't for the "mainstream science" that he disrespects so disrespectfully, he probably wouldn't even be alive. And yet at the same time, his alternative pseudosciences have done nothing for the world except move dollars from the pockets of hopeful gullibles into the pockets of people like Err-on and Ashtwit themselves.
bajac
Hello to all,
I found this thread very interesting!
I used to post at EnergeticForum as Wonju, but I decided not to continue posting after my disappointment with the people managing the site. It is kind of sad but I have to agree with you about the hidden agenda from the management of the forum. Except from Eric Dollard, the credibility of the those fellows at EnergeticForum is questionable.
However, that should not discourage us from pursuing overunity. Overunity is a fact and was taught by eminent people such as Tesla, Moray, Figuera, Gray, etc. I also have seen third party certified test report for some of the devices including the EV motor from Gray.
Thanks
