Self-sustained power generator
Started by weston14, July 21, 2013, 06:01:44 PM
LibreEnergia
Quote from: forest on July 24, 2013, 01:19:28 AM
LibreEnergia
You waste your time ! It works exactly like evey animal body, energy is taken from outside, we just don't know yet the exact process of tapping that energy.
I have only one word for that.. Bullshit.
When considering a mechanical device such as the one described in the thread originators video we know exactly where the energy is coming from and going to.
Quote from: weston14 on July 21, 2013, 06:01:44 PM
Hi , this is a link to a prototype on the making      http://www.youtube.com/watch?v=p1WR7OJHryM     it uses the kinetic energy of an object to transform it to electrical energy the fact that it gives more power than what it consumes dose not make it an overunitty device since it is not creating power but just transforming it if you would like to comment on it saying that it dosen't work give scientifical explanation and iff you would like to help you will find the link on the video if you would like to make one ask me how if you allready know  how do it I appreciate all comments and replies but most the ones giving me support supporting me Thanks .
Congratulations!
You have invented the flywheel!
(Seriously... just because you have taken the standard "motor drives generator powers motor" idea and turned it vertical.... what makes you think that you have anything new or special? You are pumping energy into a flywheel by the action of your arms and hands. Then you can draw off some _power_ at high peak rates if you like-- higher than you can achieve with your arms alone, maybe-- but this is _not_ overunity nor does it imply or even suggest that you might be able to make something self-sustaining. You are not going to get any experienced builder to try to help you make a prototype until you can demonstrate something _new and unique_ about your idea... and so far, you haven't. I am taking you seriously here, as a sincere but perhaps a bit naive researcher. You should take Mark Dansie's advice and _study_ the Simanek pages, all of them. Then try to find something new about your design that might interest a skilled builder. And never forget: power is not energy, and power multiplication devices are all around us and they are none of them OU.)
Low-Q
I have no problems accepting that you use a dynamo to power some LED's. The problem however, is that you claim you use less energy input than the dynamo can give. This is not possible. Everything in the universe is linked together - like a closed loop of chain. Pulling the chain means just that it will respond by moving and affect the complete loop accordingly.
Einsteins theory of relativity applies to all physics except singularity which is to be found in the center og black holes - where his equation at some point are devided by zero - which in turn means an impossible result with infinite gravity at an infinitly small point.
Vidar
FatBird
SUPER Great invention.
Of course it works.  Only a blind person (or a TROLL) would say it doesn't work.
Liberty
I give you credit for your effort and creative thinking.  But what I have found is that as long as you use a standard generator for power generation, it will always be subject to less output than what you put into it.  It has to do with the way a generator/alternator is designed that limits it's ability to never put out more than what you put into it.  Because the magnetic coupling within a generator, from the rotational source input power and the generating coils for the output power, the lenz effect or counter magnetic field (magnetic drag) will always limit the output to less than what you put in.  If you can find a way to get around that problem, as I have, then you will have something.
Liberty
Liberty
