New Perm Mag Engine Design 1.5 : 1 Ratio (work from magnets)
Started by Floor, August 05, 2013, 08:36:48 AM
Floor
@conradelektro
I just read your last post, and am just now, responding to your previous post as well.
My response is attached as the file "TDfloors reply 2 conradelektro 2 "  PDF
2 previous long winded post are also attached
Cheers
   floor
lumen
Quote from: Floor on August 10, 2013, 04:35:31 PM
@lumen
Hello Lumen
I was not totally able understand  the descriptions and explanations given in your last post. Can you clarify them.
Please find attached the file TD floor 2 Lumen 2
Yes, those dimensions are good.
The idea is that the cylinder is attracted to the ring magnet to the point where the field through the center hole causes an equal opposing force and stops attraction.
At this point, it also becomes easier to rotate the cylinder, in fact, there are ways to reduce the rotation force to near zero.
After rotation of the cylinder, the slide will now repel.
The forces could be very high using Neo magnets with the dimensions you are showing.
Floor
@conradelektro
           Thank you for the compliment,  and the more complete analysis.
   cheers
       floor
Floor
I am interested in examining the interaction of various shapes of magnets and magnetic fields.  I like your idea, and will consider building a device to test it.
        Thanks again
             floor
Floor
@lumen
          My previous post is to lumen
                     floor
