Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
0 Members and 56 Guests are viewing this topic.
tinman
Quote from: Clarence on April 03, 2015, 09:51:29 AM
Clarence
QuoteI power the XANTREX TRUE CHARGE 2 by    the    OUTPUT     of    the    Captor!
the charger KEEPS the battry charged and thus self powers the unit!
So to be clear,you are saying you have a self running device?.
Clarence
Quote from: tinman on April 03, 2015, 10:40:16 AM
Hello tinman,
It is the unit that says YES. the unit says so by it's performance.
Clarence
tinman
Quote from: Clarence on April 03, 2015, 10:57:01 AM
Hello tinman,
Clarence
Sounds great.
How are you measureing the units performance?.
Hoppy
Quote from: Void on April 03, 2015, 10:21:10 AM
Hi Hoppy. To be clear, the mains ground loop issue should only be an issue for the B&L device if it
is being powered from the mains. If it is being powered from a battery and inverter then
the mains should not be a factor at all in the power that the device is producing.
The only way that I can see that Kapadnadze could have been making use of the mains is if he had
a hidden wire from his device to the mains hot wire, but people who have seen Kapadnadze's device
up close seem to have confirmed that there are no hidden wires. Just the earth ground wire(s). If you
just have one wire running to earth ground from the device as in the 'aquarium' device, I can't see any way
that you could be powering from the mains.
All the best...
Hi Void,
Of course you are right in the case of Kapanadze, assuming there is only one wire to the system and that being from earth ground. However, that is a big assumption, given that any other wire would have been very well concealled.  ;)
I would like to know what voltage Clarence measures between his mains neutral and earth ground, with his device totally disconnected from earth ground.
Clarence
Quote from: Hoppy on April 03, 2015, 12:06:24 PM
Hi Void,
HELLO Hoppy,
It is beyond me WHY? people cannot get it through their HEADS that my unit IS NOT CONNECTED TO ANY MAINS AT ALL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
GET A GRIP!!!!
Clarence
