Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
Magnethos
@captainkt
I'll use the water pipe as the earth's ground. Thank you for the answer.
Magnethos
Just one more question.
How I know that the water pipe is a good ground? I mean, if there is some measurement or technique to determine that the pipe is a good or bad ground.
ATOM1
Its the surface area that's all ! Water spreads out but I don't see much power here on the proposed system also the energy will not be predictable it will have lows and highs ect .... The earths electric field is just over 7hz but that's not including interstellar radiation soaking into the earth at 8000hz and than charged alpha particles coming up from the earth core but you need a lot of fine coil to catch them. My suggestion is a negatively charged coil to catch everything ! About 1 kwh per square meter... Also remember a solar panel only converts 19% so a negative coil is best ...
ATOM1
Magnethos
I've tried again replacing the power grid ground with the water pipe. The water pipe ground is ok because I've tested it with the multimeter. The problem is that I've still the same problem as before: the breaker trips when I try to switch on the load in the output.
When the circuit is on, no problem. When I connect a load and I try to switch it on, then I get the problem.
What can be causing that problem?
seychelles
YEP IT IS EASY BUT YOU TAKE YOUR OWN RISK IF YOU DIE TOMORROW FROM ELECTROCUTION DO NOT COME TO ME OK..YOU GET A 100WATT 240 V QAURTZ HALLOGEN LAMP. YOU CONNECT IT NORMALY ,THEN YOU GET THE AC CURRENT CONSUMED BY THIS LAMP.
THEN YOU TAKE THE LIVE WIRE CONNECT IT IN SERIES WITH THE LAMP TO YOUR GROUND NOT THE TAP PLUMBING GROUND BUT YOUR ROD IN THE GROUND EARTH.. THE LAMP SHOULD LITE UP JUST THE SAME INTENSITY AS WHEN YOU CONNECTED WITH THE SYSTEM NEUTRAL CHECK THE CURRENT DRAW IT SHOULD BE THE SAME..IF NOT YOUR EARTH IS KAKA..
