Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
Yuri_L
Quote from: TheCell on August 05, 2015, 03:03:32 PM
I received the clamp meter yesterday.
In the shorted loop I have measured 125A.
<You need to reduce turn number of the inductor...>
You need to reduce turn number of the inductor to get the idle current 250mA
I hope you know how to reduce   the saturation of the core  :D
Yuri_L
Quote from: totoalas on August 05, 2015, 01:35:53 PM
is the cable loop  just like a battery cable  and what size  thanks
Size is defined by the temperature that should be not more than 40-50oC
totoalas
Quote from: Yuri_L on August 06, 2015, 10:41:45 PM
Thanks YUri  for the info
Can a toroid be used also ....  If I use a welding machine( what size for a 2 or 3 KW  output )   for the set up   Can I use the air conditioner as a load  .....  Im thinking to use the toroid  for small heating load such as flat iron  and  rice cooker
lots of possibilities....   ;)
Another question on the loop connection   is it connected in the beginning   1/4  or 1/2  of the coil turns  ???
And coil loop size more than double the primary coil to compensate for the temperature  ????
thanks
tvka
Hi Yuri,
Frankly,your video did not assure me.
Meaning, I do not see  why lamps where not lighted up to full brightness from common 220 net...
However, I prefer  not to spill the water with a child.
I have 200W industrial winding thoroid transformer. Hope it is designed properly regarding primary turn number. Without flux phi2 get 75A in the shorted loop, primary power 22W.
Feels like phi2 does the trick.
Estimated primary turn number is 700.
Please suggest what should be turn number for the counter winded portion of primary.
Is it 1:400 as in your case?
What is the purpose of the shorted loop connection to primary? It will affect fluxes anyway.
Regards,
Valdis
