Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
truongcongduc4
Hello everybody,
This is my test on the loop. I don't have the ground connection. I test it to study only.
Test with one transformer:
- The output of two transformer is not the same. The first one is 1.113v. The second one is 1.012v.
- The current in the loop is very high (450A) and the wire is very hot.
Test with two transformer:
- The current in the loop is about 8.3 A. (Because the current of two transformer is not the same).
- If two transformer is the same, the current in the loop will be 0 A.
I still need more time to test and study.
Thanks,
mariovanwyk1
Hi all.
I'm new to this forum. I've been following & studying this topic for a while now. To ensure I summarize my understanding of the working unit that Clarence put together, I carefully made up the attached schematic.
Please let me know if I have this correct.
Mario.
biel_sousa
Hello people, I'm new here, so I've been researching this captor for months and watching some videos on the internet. I realized a lot of people are using different circuits, not worrying about the grounding grid, which is the most important! some said 60 grounding bars of 3 meters were needed to operate.
on youtube I found the following video that makes the most sense and that really works, before seeing this video I already suspected that it could be a circuit similar. look at https://www.youtube.com/watch?v=-LFmmyl1JmM he used 1 grounding bar I'm leaving the schematic in the attachment, anyone there can do the same ??? I am almost sure that this scheme is what works and that may be the original of the barbosa and loyal and not this schemes that we see around the internet. it uses only one phase without the neutral and uses the earth to give DDP on the induction coil, and uses a capacitor in the ground.
Look at the comment I found in the video, it's very interesting.
"Good evening, my friends, I'm Brazilian, and our friend from the Dominican Republic has made an effort to investigate the Earth's energy grab made by barbosa and loyal, I've been investigating this project for several months, until I discovered that he used a technology that exists a lot time in "shaded pole motor" motors, what happens is that the consumption in the phase continues more in the opposite direction to the half-cycle.
During the variation of the amplitude of the flow that passes through the short coil, current paths appear that create as many magnetic fields, weakening the flows that created them and opposing them. Thus, it is possible to decrease the magnetic flux over the shaded poles when the flux is increasing and maintain the magnitude of the field while it is decreasing. It turns out that there are two pulsating magnetic fields, which are not displaced by 90º (at most 45º), but their combined effect is the creation of a weak magnetic field, FINAL RESULT, IS ANULATION OF CONSUMPTION IN THE FACE AND THEREFORE WE HAVE TO USE THE EARTH FOR CONTINUATION OF THE SEMI-CYCLE."
biel_sousa
conandrum
Hi everyone,
Clarence is not with us anymore.
I have decided to put together a short 10 page historical account of Clarence's replication of the B&L devices.
I will be posting more here: http://www.energeticforum.com/renewable-energy/20091-barbosa-leal-devices-info-replication-details.html
Let me start with this:
POST #1548 A pot of gold --hopefully:
QuoteTHE WHOLE SOB DOES WHAT IT WAS SAID IT COULD DO!
I have Had it pulling energy from the ground up tp 9.8AMPS.
all of this while the KAW meter only shows 0.07 amps supplied from the mains and at 5.4 watts.
At first I thought it was a faulty KAW so I dug out the others and tried Four more of them - they all read the same.
I have run a floor fan, my microwave, my smart charger charging my battery banks, all at the same time - still NO CHANGE ON THE INPUT FROM THE MAINs- 0.07 amps at 5.4 watts.
I was just standing there dumbfounded.
All this time the # 12 wraps on the toroid only showed .5 amps with never changing!.
The following is a quote from a short 10 page PDF document I put together called 'A historical account of Clarence's replication of the B&L devices.pdf'
QuoteMains Performance:
#1549 08-07-2017, 11:34 PM - '18.8 amps out for .07 amps in is quite an increase!'
#1551 08-08-2017, 12:55 AM - 'loaded my setup with loads equaling 26 + amps on a wall plug outlet only rated for 20 amps MAX - no breaker trip'
#1746 10-21-2017, 10:05 PM - 'I have put up to 37 AMP LOAD on a 20 amp wall socket for the unit I am still using DAILY. The watt reading shown on the KAW meter was ALWAYS very low. Be it Known AS LUC said that even the MINIMAL system Resistance WILL drop the system voltage as more loads are added.'
Shouldn't we all be retracing Clarence's steps from HERE?
I believe the PDF is a must for anyone looking into the Clarence replication.
Not only will it serve as a map of this whole thread, it will also allow you to see what each step made by Clarence was for and the progress made.
Judging character is not a measure of anyone's claims. This man, regardless of his ways and attitudes has labored for years towards this single goal. Even in his old age was undoubtedly a very capable man in all he did.
Clarence may have been fooled by B&L for 2 years but he was meticulous and adamant to get there. He may have done just what he set out to do in the end!
So the way I see it, the claim still stands as stated above and it is very clear to me.
Download the pdf below and let me know what you think:
Oh! and have a GREAT day!
