Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
isam
Hello All,
I replicated Barbosa  and Leal circuit yesterday using the schematics shared on overunity.com.  Following are my findings.
I used Toroidal transformer  220V, 500W as primary coil and powered it up from Grid using 236V AC. I used the secondary coil( black 50mm copper cable) with one loop through Toroidal with closed circuit.  I connected the Phase(Line) from grid to the secondary loop too for polarity.   My Ground seem to be very good showing 0.245 Volts between Neutral and Ground.  I created 6 loops of ground cable around Secondary coil.  Then I powered up my primary coil and  immediately the secondly coil with little humming shows about 80 amps of current in. I measured volts between Secondary and ground to be 236V.
Then I put load connected to Secondary and Ground and my 500W lamp lit perfectly.   Now the interesting part is here.
I measured my input current(from grid) and my output on to the (Phase on load)  but they were both same as 2.1 amps.   The secondary coil was still showing 80amps current.  So where is OverUnity?  Did I do anything wrong in the circuit?
Please advise if anyone has replicated it with success.  If someone is successful, then please share the exact details of primary coil and secondary( cable length, no of loops, gauge of the cable...etc)  and how to connect ground of capturing electrons from ground. This may help.
The test I did leads lead me to the conclusion till now that there wasn't any Overunity in the circuit.
Thanks to all.
leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
captainkt
@ isam, I have tried all ways to connect this circuit, if you look at it all that is happening is the live goes almost direct through the load to earth and lights the bulb the rest of circuit is not used.
Keith       PS secondary amps around 100 in my circuit but has no effect on load up or down.
nelsonrochaa
Hi is my last video https://www.youtube.com/watch?v=KAtRv6PneNs.
I will no post more videos about this circuit  because i have other projects in my mind and in develop.
I see many people trying to replicate a patent barbosa and interestingly not seen at the beginning of the patent references stanley Mayer patent. It's just a tip not everything that glitters is gold, everyone just eyes in barbosa patent ignoring any description of Farady not referring to the bibliography used for the construction of the patent.
Good luck to all.
Acca
 Thanks to NelsonRochaa on overunity thread for  "Barbosa"
Barbosa power generator video clip(s) on Youtube below..Duplicators !!!
Acca...
https://www.youtube.com/watch?v=wbNvUZT4NC4
