Energy from the Ground - Self powered generator by Barbosa and Leal
Started by hanon, August 13, 2013, 08:01:16 PM
Hoppy
Quote from: a.king21 on December 22, 2014, 10:57:24 AM
No readings were taken.
That's jogged my memory as I think you said way back that TK would not allow your team to take measurements. Its a pity but quite understandable because a clamp reading along the entire length of the braided earth lead would have likely revealed a lot about how the device was operating. In consequence, we are left to endlessly speculate.
a.king21
Quote from: Hoppy on December 23, 2014, 03:21:20 AM
The "not allowing measurements" bit related to the second device we commissioned. This was either 10 kw or 20 kw I cannot remember which. (I did not specify it, which is a pity). Anyway the team turned up with a heap of state of the art technology which spooked Tariel.
Hoppy
Quote from: a.king21 on December 23, 2014, 08:15:39 AM
Not surprised! I doubt he had ever used anything like it but its interesting to wonder why he would not even allow a clamp meter which does not even involve breaking into a circuit. After all, he had no problem allowing one to be used on the green box device setup. Maybe there was no electric field strong enough to interfere with an accurate reading taken off the earth cable.  ;D
Zeitmaschine
Quote from: Hoppy on December 23, 2014, 12:48:14 PM
Because the Aquarium II braid is not a braided earth lead but an antenna.
Now guess what: According to my tests with some Avramenko plugs, a plug collects more energy when the antenna is made of braid not ordinary wire of the same length. Don't know why. Investigating ...
So that seems to be the reason why Kapanadze needed coaxial cable: to strip and use the braid. Having the same problem currently.
Hoppy
Quote from: Zeitmaschine on December 23, 2014, 09:50:10 PM
I doubt that TK used the braid off the coax-cable. Looks too intact. He probably used a tubular braid supplied in rolls.
Yes, I suppose it could be an antenna connected to a powerful radio TX.  ;D
Merry Xmas
