totoalas
Increase the induction conductivity in the secondary loop with ground
truongcongduc4
Think about this image. Extract free electrons from the ground base on the high current in the loop. How to make the current in 5 increase ?
havuhung
Hi @truongcongduc4,
Think about this: The law of conservation of energy is still present, you want to extract from the ground up charge your device (temporarily considered negative charges), you must have a corresponding positive charge to pull it up! Why? As the negatively charged surface did not (generous) to run up to you for free! So how are you (with interest) in terms of energy use??? :D
Dave45
If I were working on this I would bifilar the secondary one end to ground through diode, pump energy out of the ground.
There's lots of options using bifilar coils on both the primary and secondary, ground connections, antenna connections, outside coils to draw power in, capacitors to bounce energy.
Pump the bemf(positive energy) from a coil into a ground wire and see what you get back.
Im not saying any of this works but open up the system let it breath give yourself options to work with.
Dave45
Quote from: havuhung on December 30, 2013, 06:23:10 AM
Hi @truongcongduc4,
Now your talking, I like it.
Use pos to attract neg
