FatBird
This Brazil Captor unit is just FOOLING THE METER.
If you Follow the Mains HOT wire (wire 1) down you can see that it exits the OUTPUT (wire 4).  This is the SAME MAINS HOT WIRE.
They Fool the Meter because the Output uses the EARTH GROUND and NOT the Mains Neutral, thus FOOLING the Meter.
However, I suspect that their units CANNOT fool the New SMART Meters being installed around the world.
The coiled Black Wire serves NO useful purpose EXCEPT to show around 125 Amps circulating in itself.  EXCELLENT for fooling people though.  LOL
---->   A VERY SPECIAL THANKS goes to Mr Ariovaldo for BUYING a Captor, taking it apart, and Drawing the SUPER GOOD Professional Schematic (see 3 posts above).
fer123
Hello mr, according with your conclusion how you polarized ground wire to become neutral and extract  12.1kw electricity? Thanks.
havuhung
Quote from: FatBird on May 04, 2014, 08:16:20 AM
Hi All,
This can happen with the right kind of old electrical kWh meters. But with a new type of meter, power consumption devices in your home, you are not connected to the neutral wire phase, kWh meter is still running!!!
Perhaps the kWh meter in Brazil are a bit above cons. Well the evidence is convincing: They suggest you to perform multiple grounding rods in your home area!!!
Neo-X
I tried to replicate this using 220-110 volt stepdown transformer. I plugged the transformer to the outlet then i put the tester probe to the transformer output. It read the normal 110v but when i add the wire to one of the output of the transformer connected to the ground, the voltage suddenly goes up to 150v and the transformer heats up very rapidly. Its like it shorted out so i discontinued the experiment. How is it shorted out when im using an isolation transformer?
havuhung
Hi Neo-X,
Transformer 220/110 of you are testing; What happened that you mentioned above, may be between the primary winding and a secondary winding insulating layer of paper had no good! . .
