a.king21
Quote from: captainkt on December 15, 2014, 08:42:24 AM
Hi zeitmaschine, where are you putting load in your captor circuit, across the spark or in series with the spark or somewhere else? Also I am not sure how long inverter will last with high voltage up against output, When I try to mix voltages in my circuits inverter blows.
Keith
Mine too - which my makes me think we're on to something, especially since my spark generator used little noticeable power to create.  ps Are you any good at fixing blown inverters? I've at least half a dozen.
NickZ
  Maybe what is needed to avoid problems with the inverters, is to make your own step down transformer, connected too a full bridge rectifier, using the proper diodes, and some caps to filter it.  Or repair and improve the inverters that you already have.
  I can light a 25 watt bulb, here where is live, on just the one hot line from the grid, and outside earth ground. But, not a 100 watt bulb. A system that improves on that small source of power, and that could give more out than that, would be nice to know about.
ElectricPirate
Guys dont waste your time on Barbosa and Leal patent. This is no difference in Kapanadze patent, full of words but have no detailed instruction and diagram how to build their device. If they really want to share their device to the people, they will make an instructional video or tutorial how to make one. Although they patented this in my opinion it is not yet fully disclosed. They patented this for their own interest. What they really want is to spread to the world that they built this amazing invention to capture the attention of many investors and help them to mass produce their device then sell it to the public. They dont really like anyone to replicate their device because if anyone can replicate it, who will buy they their product. This is all about money and not helping people.
a.king21
Quote from: NickZ on December 15, 2014, 08:17:48 PM
I did this experiment and found I had to wait for the ionic ground pathway to be formed. It was weird, watching an incandescent  light bulb flicker into life. After that I succeeded  in powering a 2 kw kettle. The ground needs to be wet though.  It was not free energy, and I found I was using half power. Weird.  I suspect it is because the neutral is grounded in the UK so I was using half the wave.
Clarence
Hello @ ElectricPirate and All,
Maybe this FULL INFO Kapanadze  item might lift your spirits to keep looking for an answer - I know I am busy as a beaver experimenting on B & L.
whenever I get something worth showing I will show it. Cheers.
Clarence, thanks.
