We have some new technical information from Clarence:
C. HOW do you know when you have reached the point when you are at
the needed Level of potential? ???
SIMPLE!!!!  when the voltage from the ground return NEUTRAL across
the CAPTOR output PHASE
reads the EXACT SAME rms as is shown
ACROSS THE INVERTER OUTPUT then you are ONLY AT THE TIPPING
POINT!!!! you will STILL have  to add MORE RODS!!!! say 10 to 20 -
and after you apply loads and the rms on the CAPTOR output starts to
drop somewhat you  can KNOW you will still need some more
potential from the earth by adding a few more rods.
" ITS CALLED ENERGY FROM THE EARTH"  the NAME of the system-
STICK IT IN YOUR SKULLS people!!!!
I added the annotations for "Ground Grid Return" and "Ground Grid Input" to that cut-off BroMikey schematic and attached it here.
Where is this measurement on the schematic, or please ask Clarence:  "the voltage from the ground return NEUTRAL across
the CAPTOR output PHASE."
Certainly you you put one of your probes on the Ground Grid Return line, because that is connected to a neutral.  Where do you put the other probe?
What about this measurement:  "the rms on the CAPTOR output"
Is that the same measurement, or do you put your probes somewhere else?
skribat
Quote from: Hoppy on April 22, 2015, 05:37:49 AM
Could you show us the evidence for this please?
I will have to search my archives for it so it may take a while, I think several of the latest Kapenadze videos were taken down from you tube, the latest was taken at an installation launch open to tradespeople, where they showed a working device putting out (I think) 10,000 kw . .. the previous ones showed them in an industrial unit assembling what appeared to be sub-stations using 50,000v oil filled transformers ..  I would have liked to have stored the videos but my ADSL connection is slow (out in the sticks) and causes me problems. .. meanwhile I think you might like to see this .. .. https://www.youtube.com/watch?feature=player_detailpage&v=E0bOK7ChwbQ#t=595   explanation and demonstration of B&L type circuit. .. with measurements ..   It may take some time to find the Kapenadze I work most of the day and don't have as much energy as I used to have, old age creeping on.
