10,000 Volt Water Battery From tins and Water
Started by markdansie, August 22, 2013, 08:42:07 PM
Pirate88179
Quote from: TinselKoala on August 22, 2013, 09:40:58 PM
And I am still, no kidding, looking for a good explanation of the effect shown in this video with the "Quantum polarization panel".
http://www.youtube.com/watch?v=f-aP7sk48jw
That's easy.  You have built a rotating magnetic field electro-static capacitor.  Now, had you filmed that below the equator, the sphere would have rotated in the other direction.  Hopefully, you did not damage the space-time continuum very much by running that.  Hopefully.
Kator01
Tinselkoala, do you have a link for me to understand the priciple of this "quantum.leach-out-thoerie"
I missed this subject.
Another question: was it you who posted the vid about the copper-zinc-cell with the regenerative collaps-spike-circuit ?
Do you have a drawing of this circuit ?
Kator01
Quote from: Kator01 on August 23, 2013, 07:00:15 AM
Heh.... actually most of what happens in that video is "simple" electrostatic field interactions. The part that I genuinely do not understand is the effect of the "Quantum Polarization Panel" in the last part of the video. When the flying ball gets tired, then the insertion of the panel on the outside of the housing causes a rapid speed-up again. The bamboo chopstick holding the panel acts as a very high resistance bleed resistor, but I still can't quite explain the action of the panel. Nothing is "faked" in that video, the high voltage comes from the small VDG machine which uses an ordinary rubber band (purple, IIRC) for a belt and a little hobby motor to turn it.
Kator01
No, that wasn't me, sorry.
markdansie
Hi TK
When I put the video up I was sure that you would come forward with some of your past devices.  Thanks you for doing so.
I am also always surprised by Pirate (first year MIT online )
I believe education is always important and i learn from both of you
Many thanks
Kator01
Tinselkoala,,
what is this "Quantum Polarization Panel" made of ? Just a metallic foil or an isulater-foil ?
For me it looks as if the field-gradient is increased.
May be it has to do with what the german scientis Prof. Turtur has found. He prooved that ZPE is flowing permanently in into an electrostatic field thinning out into the enviroment as the field moves out and away frome the field-source:
Theory:
http://www.ostfalia.de/export/sites/default/de/pws/turtur/images/1_Schrift_03f_englisch.pdf
First practical test ( unfortunately in german ) you can see the principle at work:
http://www.youtube.com/watch?v=B5m9wM2feEg&feature=youtu.be
does this give you a clou ?
here it is in english:
http://www.youtube.com/watch?v=IiC2IGLl90Q
Video-Series in english 1-3:
http://www.youtube.com/watch?v=YeVQpK243ho
http://www.youtube.com/watch?v=qjdEOPhwLU8
http://www.youtube.com/watch?v=Dnz-Qjtz_I8
final test in a high-vacuum-chamber done at a german university:
http://philica.com/display_article.php?article_id=141
Kator01
