Rosemary Ainslie Quantum Magazine Circuit COP > 17 Claims
Started by TinselKoala, August 24, 2013, 02:20:03 AM
poynt99
Quote from: TinselKoala on January 10, 2014, 07:28:27 AM
For example, it was shown BY ME, long ago, that a negative bias voltage supplied in lieu of the Function Generator would produce continuous Q2 oscillations. The ACTUAL process by which Q2 is turned on and made to oscillate with the supply of a negative bias voltage is detailed in the video series that I posted a couple of days ago.
TK,
I could be wrong, but I'm fairly sure I discovered and posted about this prior to your demonstrations. I even designed a "High Frequency Burst Oscillator" which takes advantage of this negative bias.
Quote from: poynt99 on January 10, 2014, 10:43:21 AM
TK,
Yes, I'm sure you did. You did a lot of analysis while I was still "on a break". I think my earliest video illustrating continuous oscillations using a separate bias battery was probably this one, from April 2012:
http://www.youtube.com/watch?v=fC7zJouJAoU
While looking for that, I also found this old thing, from August 2009, where I actually do boil water using the Quantum single-mosfet circuit, driven by a pulse generator instead of the 555 circuit, and I show several interesting things on the Fluke Scopemeter's display including the aliased combs that Ainslie claimed were "random aperiodic Hartley oscillations" when her sycophants made them at the time.
http://www.youtube.com/watch?v=C7zQdplnCA8
poynt99
TK,
If you look at the posts from around that time, you'll see that Rose was reluctant to believe that all that was needed to make her circuit operate was a negative DC bias. And partially to prove it (and partially to use it for power testing tutorials), I designed the high frequency burst oscillator. I never did build and test it, but it worked quite nicely in the sim, and one can not really tell the difference between its output and that from her circuit, when mine is in burst or pulse mode (also does continuous oscillation mode).
PS. The file date on the scope capture "burst_osc_scope01.png" is 2011-07-13.
Yes, that work of yours took place while I was working on something else. I didn't resume work on Ainslie's claims until February or March of 2012, according to the video record. 2011 was taken up with other things of greater importance. I doubt if I was really paying much attention to Ainslie in 2011, although I did try to keep up with the forum posts. I stopped playing around with the single mosfet Quantum system in late 2009, then did a lot of work on Steorn's Orbo claims during 2010. Then a little bit of Rossi e-kitty rebuttal in early 2011.
How time flies when you're having fun, eh?
poynt99
Indeed.
And how much fun did we have kicking Steorn's butt over the bogus Orbo pulse motor measurements? Damn I did a lot of sims on that thing too.  :o
