Self accelerating reed switch magnet spinner.
Started by synchro1, September 30, 2013, 01:47:45 PM
conradelektro
Very bad scam with the Hendershot generator http://thehendershotgenerator.com/paygear/
For 47.-- you can buy a miracle! I really hate this, so stupid and so bad!
I hope synchro1 has nothing to do with this bad scam?
The absolutely total stupid sales pitch starts at about minute 16 in the video, you will solve all your power problems by buying some paper for 47.--
Synchro1, are you playing me along and are you laughing when you write your posts in this thread?
Greetings, Conrad
synchro1
@Conradelektro,
                        The Hendershot generator apparently only worked intermittently if at all. I'm not trying to sell it. You have to fly the "Synchro Coil" by hand to get it to put out copiously. The neutral zone is only a hair's width. The poor tolerance of your needle rotor is enough to wobble the zone across the face of the magnet stack, and shift the polarity. The power in the shifting poles is awesome compared to the tiny micro millimeter distance you need to move through the zone. You have to hold the coil and position it artfully to get the full output. The zone is more fluid then solid. The automatic fine tuning positioner is the hurdle that caused me to stop my progress. I considered remote servos and sensing circuitry, but the mechanism was too cumbersome and retarded in response to be practical.
                         The coil will not continue to work in a fixed position for long. You have to sit there on an adjustment screw to get it to operate maximumly. This is potentially a kilowatt generator, perhaps thousands of times overunity. Hendershot deliverd over 40 horsepower for the Army Aircorps in Philidelphia. Nicola Tesla and Charles Lindburg were at the demonstration. The motor koncked out, and was shelved. This problem can be overcome I believe with the levitator positioning circuitry.
                         Wesley Gary was the first inventor to analyze the neutral zone. Look once again at schematic  number 3 and 4 below. You can see the polarity reverse as the keeper travels across the zone. This distance is only a split hair in width! Think of the power it would take to generate that shift in an electromagnetic coil! That's the power we get to recover with the tiny motion across the zone. Hendershot was a handyman with the "Touch" required to milk the power from the generator.
                        The levitator circuit can turn your experimental coil into a powerful and practical generator that will have the promise to alter our Geo-resource economy dramatically. I am not flirting with you as a jokester. This is very very serious business.
conradelektro
Quote from: synchro1 on December 17, 2013, 04:27:49 PM
The poor tolerance of your needle rotor is enough to wobble the zone across the face of the magnet stack, and shift the polarity. The power in the shifting poles is awesome compared to the tiny micro millimeter distance you need to move through the zone. You have to hold the coil and position it artfully to get the full output. The zone is more fluid then solid. The automatic fine tuning positioner is the hurdle that caused me to stop my progress. I considered remote servos and sensing circuitry, but the mechanism was to cumbersome and retarded in response to be practical.
                         The coil will not continue to work in a fixed position for long. You have to sit there on an adjustment screw to get it operate maximumly. This is potentially a kilowatt generator, perhaps thousands of times overunity. Hendershot deliverd over 40 horsepower for the Army Aircorps in Philidelphia. Nicola Tesla and Lindburg were at the demonstration. The motor knocked out, and was shelved. This problem can be overcome I believe with the levitation circuitry.
@synchro1: fair enough, thank you for the explanation. In fact, your explanation sounds much better than claiming "I have done it". A simple solution would be the most incredible thing. The difficulties you describe could explain why nobody has done it till now.
I definitely do not claim that I can solve it, but I will investigate a bit. It would be good enough to see some inexplicable output at least for some seconds. That would warrant further investigation.
The levitation circuit does not sound good in my ears, I rather think about some type of servo driven by a microprocessor which reads a sensor. The question is "what sensor"? May be a one sided Hall sensor (which only sees one pole) could help.
May be one only tries to move the coil back and forth through the sweet spot to flip the polarisation, instead of keeping the coil in the fluid zone.
1) coil is too close to spinning magnet
2) move the coil away till the magnetic field flips (seen by the one sided Hall sensor)
3) move the coil back towards the spinning magnet till the magnetic field flips
4) repeat at 1)
A movement of only a tenth of a millimetre should be enough? May be Hendershot vibrated the coil with a spring and a solenoid, like the electric bell http://en.wikipedia.org/wiki/Electric_bell
And as you speculate, may be the little wobble of my magnet spinners does the trick? It should be some random wobble which could move the sweet spot often and far enough?
Just dreaming. And there is no hurry, the world can wait for the miracle a few more weeks.
Greetings, Conrad
gyulasun
Hi Conrad,
When you have time, look at this post on this neutral zone, it includes a short video too to show the change of the poles as per the distance is varied: http://www.energeticforum.com/renewable-energy/12413-mr-lester-j-hendershots-magnetic-generator-15.html#post243142   Graham's (member GSM) posts on Hendeshot and on Wesley Gary's setup are worth reading in that thread.
Years ago I also tested the presence of the neutral zone, using an AM radio ferrite rod (with rectangular cross section) but I did not have much help to construct a good mechanical setup so had no chance to explore the power capabilities. The neutral line exists of course, the distance how far away or closer this line is with respect to the magnet, it depends on the strength of the magnet and probably the facing area of the soft iron core towards the magnet and on the core permeability.
Greetings, Gyula
conradelektro
@Gyula: Thank you for the information, very interesting. I am intrigued and will investigate. The "neutral line" seems to be something which is not a mere myth. The Hendershot tale is a bit too far out for my taste.
I wonder whether synchro1's "tube magnet" (diametrically magnetised ring magnets in a stack) is equivalent to the horse shoe magnet of Wesley Gray?
Or is the spinning magnet the "horse shoe magnet"?
It seems to be essential to do the experiment (from the video you cited and from at least two Gary patents) with a horse shoe magnet? Did you use a horse shoe magnet in your experiment with the rectangular ferrite rod? But it could be that at Gary's time one simply had no other magnets easily available?
Please look at the attached drawing, is A or B the euivalent of a horse shoe magnet or none?
Greetings, Conrad
