Self accelerating reed switch magnet spinner.
Started by synchro1, September 30, 2013, 01:47:45 PM
synchro1
@Conradelektro,
That's what everyone's fraught with anticipation to finally see. I did have one last question for you; What gauge magnet wire do you plan to wrap the magnet bobbin with?
synchro1
The "Synchro Coil" is a "flux field generator" not an output coil. The permeability of the magnet core is zero, not above ferrite because it's completely saturated and can not take on any further magnetizem. That's why it's worthless as an output coil core. This coil is not an output coil!
http://www.youtube.com/watch?v=Dr85aHLmB1g
Output coils will not work from behind potted plants like Lidmotor's Maggie! Remove the tiny neo sphere from inside Maggie's core, and the LED'S go out! That's because Maggie is not an output coil, but a flux field generator just like the synchro coil.
synchro1
Quoting you:
"QuoteI feel the experiment on increased magnetic field strength per watt should be conducted with the coreless spiral pancake as patented by Tesla".
The above statement does not make any sense.  Notice that nobody reading the thread tried to correct you?  How can you (as in forum members) progress if you don't try to correct each other and get yourselves collectively up the learning curve?  I will leave it to you to figure out what's wrong with your statement or you and your peers on the forum together to try to figure out what is wrong with the statement.  If nobody discusses it then nobody wins!
Milehigh has done himself a great disservice here by insulting everyone on this forum. I am personally  sick and tired of his outrageous pride and arrogance. I will seek to stricken him from commenting on this thread altogether if he doesn't bring his conduct into line.
Synchro1:
If you were a keener you would try to figure out where you were wrong instead of just being a sourpuss.  There is no such thing as "magnetic field strength per watt" and this is forum and a thread where we discuss real electronics.  So now that you know where the problem is, that's half the battle.  You have an opportunity to pull yourself up by your own bootstraps if you want to.
It's time to just sit tight and let Conrad do his thing.  We don't need the histrionics.
synchro1
