Self accelerating reed switch magnet spinner.
Started by synchro1, September 30, 2013, 01:47:45 PM
conradelektro
Quote from: synchro1 on January 06, 2014, 03:06:06 PM
@Conradelektro,
You couldn't change a flat tire. The picture is a picture of magnets. The coil has nothing to do with the magnets. You're an "Ivory Tower Egg Head", bub. I wouldn't trust you to shine my shoes. You're in Liliputia! Here's where to shop for those kinds of "Man Size" magnets:
http://www.kjmagnetics.com/products.asp?cat=16
It is not a question of getting some magnets or of showing a photo of some magnets.
A sane person would just show clear measurements and would build several versions of his great discovery and describe it in a concise way. You would be on to the greatest discovery since electricity was discovered.
You just spin a strange tale. Always wiggling away from really showing something useful. Always changing to some nonsense or to some unimportant subject (like a photo of a magnet). Always avoiding the real issue.
Over and out of this nonsense thread.
Greetings, Conrad
synchro1
@Conradelektro,
I spend the winter in the tropical paradise of Costa Rica where the winter weather's warm. It's no problem for me upload a video demonstrating the effect once I return home in six months. Your turn to be patient!
conradelektro
Quote from: synchro1 on January 06, 2014, 04:41:28 PM
@Conradelektro,
Fine, please demonstrate your great discovery whenever it is convenient for you. In the meantime, let's do something useful. I am sick and tired of words.
Greetings, Conrad
synchro1
@Conradelektro,
Imagine eight of those 40 lb diametrics coupled inside an electrical conduit, then wrapped with one layer of 32 gauge wire and over that another layer of 16 gauge wire going in the same direction. They're connected in parallel. There's a fast swirching diode and a capacitor in series between the thick and thin wire on the other end. We have a total of 360 lbs of pull force inside the conduit. Cook's original was an LL-LL tank . This is now a modified LL-C tank for the self assisted oscillation. You can bet you'll be able to measure spontaneous output in the capacitor. This I call the "Cook effect".
You can position this "Cook Coil" very close to a spinning rotor without causing attraction. The output that accrues there has nothing to do with rotor induction at that point. None of your tests were conducted in accordance with any of these conditions and all your findings were false.
I modified the winding and found it worked with just the 32 gauge wrapped series bifilar, but without the powerful magnets it's hopeless. I didn't know it wouldn't work with weaker magnets. Now I do. So at least we know that much more now then before, and I think it was worth it, so thanks anyway for trying.
Best regards,
Synchro
conradelektro
Quote from: synchro1 on January 06, 2014, 05:26:12 PM
@Conradelektro,
Imagine eight of those 40 lb diametrics coupled inside an electrical conduit, then wrapped with one layer of 32 gauge wire and over that another layer of 16 gauge wire going in the same direction. They're connected in parallel. There's a fast swirching diode and a capacitor in series between the thick and thin wire on the other end. We have a total of 360 lbs of pull force inside the conduit. You can bet you'll be able to measure spontaneous output in the capacitor. This I call the "Cook effect".
Best regards,
Synchro
Fine, fine, demonstrate that in a clear way and with all components clearly specified in six months or whenever. Then may be I listen to you again. In the meantime, words will not help any more. Way too much has been written by you.
It was my own decision to do tests, so do not worry, I take the responsibility for my follies. I do not resent time spent on strange endeavours, but I do not like strange tales span over and over again. Show something in a credible and straight forward way without the hype and I am ready to try again.
It is fine if you can not do tests for a six months or for a year, but spare us the words. Only measurements count the rest is just vapour. In all the strange tales I read in the OU forums there is never something tangible. Words, words, words, words, words, words, words, ...........
And again I have to tell you, a bigger magnet can not do anything more in principle than a smaller magnet. It is the hallmark of a delusion that faster and bigger does it. It does not help to talk a real test down, it speaks for itself. I do not have to prove that your concept does not work. The burden of proof is on you.
Greetings, Conrad
