Self accelerating reed switch magnet spinner.
Started by synchro1, September 30, 2013, 01:47:45 PM
synchro1
Helical Plasma Vortex High Voltage Neodymium Magnet Xenon Flash Tube
https://www.youtube.com/watch?v=vze8f3K00Gc
I think starting the spinner with a hall effect transister and accelerating the sphere to super high velocity in close adjacency to the arc lighter plasma vortex would induce the secondary spin!
synchro1
The effect of a millions of RPM spinning neo magnet field on already spiraling plasma must be tremendous and may help trigger the fusion reaction!
synchro1
                      Plasma Vortex Reactor
A sphere  magnet centered inside a toroid coil encircled by a vacuum tourus tube within a ring magnet.
The high speed magnet spinner helps to accelerate the plasma in the surrounding tube. The powerful field insulates the magnet and the coil from the plasma.
Ounce the self circulating plasma begins to spin the magnet sphere, the power coil switches over and generates power as an output coil.
I wonder if it would work to connect the ground wire to the magnet sphere? One electrode to the outer ring, the other to the magnet sphere. The same circuit powers the plasma and the ball spin. We can energize the plasma with the hivoltage spike from the power coil.
synchro1
What if we spin up a ball inside a plasma induction tube? The collar stators can help power the ball. The same pulse from the the power coil circuit can accelerate the plasma in the tube! Tons of Tesla's and 60 KHz!
synchro1
The round induction lamp is electrodless. The excitement is from two electromagnets. The spin setup would take a toroid power coil, each side faceing an electromagnet. The EM´s would be wired in parallel so their poles would be faceing the symapathetic pole of the toroid face, N and S. The power torus would be standing up inside the round lamp. One pulse would energize all the coils and four poles! One half of the toroid and power coil would be negative together on one side , then the other.
