Self accelerating reed switch magnet spinner.
Started by synchro1, September 30, 2013, 01:47:45 PM
synchro1
4 coils wound in asymmetrical direction! Two sets, of oppositely wound coils around a toroid. Now, run opposite phase a.c currents through them, and you get some "Motion in The Ocean."
"The converter only works with 2 Phase Alternating Currents for the Transformer has TWO sets of windings ( PRIMARY), 4 wound coils is connected in a manner that they fix the magnetic lines of field in 90 degrees.. The Converter/Transformer is powered with TWO Primaries on the toroid, the 4 coils is wound in a Asymmetrical Manner".
synchro1
My most recent thoughts on this "Self acceleration effect" has brought me to conclude that spinning plasma forms within the Reed vacuum tube and begins to self rotate and grow magtnetic. The intense heat is insulated from the glass wall by the magnetic containment field from the fast spinning Neo tube. I think that the electrodes vaporize and that magnetic molecules help accelerate the spin soup.
Outerspace is filled with self spinning Plasma spirals that form spontaneously. I believe the magnetic field generated inside the spinning Plasma powers the Neo tube with no electric current passing into the electric coil. The magnetic plasma is the prime mover. A cheap fusion power plant!
synchro1
A laboratory creation of a Parker Spiral in 2020.
synchro1
"The team recreated the Parker spiral in the laboratory by forcing a helium plasma to rotate in the Big Red Ball device (a plasma confinement vessel). Once the plasma spun fast enough, its magnetic field formed a spiral".
The vacuum Reed switch is filled with the same inert helium gas as the laboratory vessel!
synchro1
I bet the magnetic field generated by this spiraling plasma would spin a small neo sphere!
